H90 – Delay volume
Home Forums Products Stompboxes H90 – Delay volume
Viewing 4 reply threads
    • #173177
      Baccetti
      I’m wondering how I could reduce the volume of the delay repeats. I would like the first repeat of the delay to be quieter. Does this option exist?
      Thank you,B
    • #173211
      apalazzolo
      Headspace has individual level controls for up to four repeats.
    • #173213
      Baccetti
      Aha, ok. What about Vintage delay or Digital delay.. Headspace is quite complicated to figure out.
    • #173390
      If you just want the overall volume of the delayed signal to be quieter, the Mix parameter will accomplish this for any delay algorithm. At 50% the dry signal and the delayed signal will be at equal volumes. Try setting mix between 30-40% to turn the delayed signal down a bit.
      If you want to control the volume of specific delay taps, UltraTap can do this, but it’s not quite a simple delay. You can experiments with the Taper parameter, negative values will result in the first delay tap being quieter than later delay taps: https://cdn.eventideaudio.com/manuals/h90/1.5.2/content/algorithms/delay.html#ultratap
    • #173424
      Baccetti
      Mix parameter did the job. Setting mix between 10-15% works best for me. Thank you.
