H90 Diatonic – Learn from Aux Switch?
Home Forums Products Stompboxes H90 Diatonic – Learn from Aux Switch?
Viewing 3 reply threads
    • #171599
      andychar
      Currently I see that while using the Diatonic Harmonizer algorithm, the Learn function is possible via one of the built in performance footswitches, but since it’s not a performance parameter I don’t see an option to trigger this from an Aux switch.  Is this possible?
    • #171605
      As an example, assume Diatonic is in Preset A.  Click on the Perform knob.  Use the middle LED button to cycle through the parameters until you reach LEARN.
      Press & hold that same middle LED button to assign LEARN to an external controller.  In this sub-menu, you can even Learn (Ctl Source) the LEARN (Parameter).
    • #171646
      andychar
      Thanks @brock for the advice.  Right now I use FS2 for Active/Bypass and FS5 for Learn, but I’d like to assign Learn to Aux Switch 1 for less toe tapping.
      If I follow your instructions it seems like the assignments are made to the builtin foot switches but can be also triggered externally.  If I also assign FS5 to be triggered by Aux Switch 1 then it does trigger Learn but also triggers Active/Bypass as well as tap tempo!  That seems odd.  What would be nice would be to assign Learn to an external controller without a dependency on the built in foot switches.
    • #171647
      andychar
      I figured out that the Aux Switch was also assigned to Active/Bypass + Tap Tempo and was able to disable that.  So your suggestion does work if the Aux Switch mirrors what FS5 is doing.  Thanks.
