H90 double stereo output routing
Home Forums Products Stompboxes H90 double stereo output routing
Viewing 4 reply threads
    • #189504
      Rexindigo
        Hi, is it possible to do the following:
        -guitar goes into amp modeler
        – out of modeler stereo loop into stereo input H90
        – Stereo output (1+2) goes back to modeler stereo loop and (through Modeler CAB IR) into PA
        -Stereo output (3+4) goes into stereo power amp and stereo cab
        how do i have to set this up?
        thank you for any help, cheers REX
      • #189508
          Hi Rex,
          Yes, this is possible using the H90’s insert routing.
          • Make your connections as described above
          • Press the Routing button on the H90 to access the Routing menu
          • Turn Quick Knob 3 clockwise until it enables a stereo insert
          • Turn Quick Knob 2 to place the stereo insert at the end of the H90 signal path
          • Turn the Perform Knob to get to the 2nd page of the Insert parameters.
          • Adjust the Insert Mix to be at 50% (if you don’t do this, there will be no output on 1-2)
          • Adjust the Send Level to change the volume of the signal for the stereo power amp/cab.
          More info about the insert routing can be found here: https://cdn.eventideaudio.com/manuals/h90/1.9.7/content/edit-modes/routing.html
          Let me know if you have any questions or issues with the setup.
        • #189510
          Rexindigo
            Hi tbskoglund,
            thank You for the fast reply.
            One last question:
            Can i set this up global, or do i have to configure this in evry patch?
            Thanks for your  help
          • #189511
              You’re welcome. You’ll need to setup this routing for each Program.
              Using H90 Control, you could create this Program as your default, copy/paste it a few times on your Program list, and then create your new Programs from that default Program so you don’t have to keep adjusting the routing.
            • #189512
              Rexindigo
                Thank You very much!
