H90 Error
Home › Forums › Products › Stompboxes › H90 Error
Viewing 3 reply threads
    • #184732
      Antonyo
        Hello! There is a small problem:
        When trying to export a preset, the H90 Control application displays the following message:«Device returned error response code 0x02!»What does this error code mean?..
        And how can this be fixed?
      • #184733
        Antonyo
          The problem seemed to be solved after I exported one of the programs entirely.
        • #184735
          Antonyo
            Oh, no. The problem hasn’t gone away.
            I’ve found that factory presets are exported to the computer without any problems, but the presets that I made myself give the above-mentioned error.
            It seems to be exported from the library too.
            But not directly from the loaded Program. At the same time, the programs themselves are exported completely normally.
          • #184742
              Sorry for the issues you are having. This happens when you try to export a Preset that has not been saved to the library. Please click the 3-dot icon for the Preset, select “Save to Library”, and then try the export again.
              Sorry for the confusion. We’re looking into improving this.
