Home › Forums › Products › Stompboxes › H90 error? Preset B feeding into Preset A
- This topic has 7 replies, 3 voices, and was last updated 1 year, 6 months ago by
jackbrighton.
December 18, 2024 at 8:11 pm #187123
Got an H90 a couple of weeks ago and everything was amazing. Suddenly, literally overnight, Preset B is feeding into Preset A in every program. Example: Weedwacker is in Preset slot A, and Bouquet Delay is in Preset slot B, but you hear the delay before the distortion, and if the Mix on Bouquet/Preset B is turned up or down, it also turns Weedwacker/Preset A up or down.
This is happening with every program, but it was not happening until this morning.
I’m running the H90 in mono/series routing, guitar into In 1, and Out 1 straight into an amp. Firmware and H90 app/Mac are the latest release (1.9.7.181 and 1.8.16).
It’s possible I’m being stupid and somehow changed something that would account for this, but I’ve looked through every setting (and the manual again) and verified that everything looks correct. (I did not switch the order of A and B in the app.)
Right now my H90 is unusable so I’m hoping there’s a solution. Any suggestions?
December 18, 2024 at 9:17 pm #187124
That is weird. The only way for this to happen is if someone changes the order of the presets in the routing menu either by pressing the first quick knob on the pedal or via the app. By any chance, did you import a playlist that was created in dual mode into insert mode or something like that?
December 18, 2024 at 9:27 pm #187125
Thanks for the speedy reply! I haven’t imported any playlists, so that’s not the issue.
December 18, 2024 at 10:09 pm #187126
The only solution is to manually swap the order of the presets for the programs you use. I just don’t see how this could have happened globally.
December 19, 2024 at 11:14 am #187132
Swapping the preset order didn’t fix it, so I did a factory reset and it’s working fine now. I must have done something to mess it up, but it’s still not clear what that was. (And yes I read the manual.)
Anyway, the issue is resolved.
December 19, 2024 at 2:34 am #187127
check the manual
December 19, 2024 at 11:16 am #187133
Sorry you ran into this problem. We appreciate you reporting back. We haven’t seen this issue before, but I’m glad the reset fixed it for you.
December 19, 2024 at 2:40 pm #187140
Thanks for your quick responses on this. Also a quick kudos for the product FAQs, which are a big help.
