Home › Forums › Products › Stompboxes › H90 exp pedal setup
- This topic has 7 replies, 2 voices, and was last updated 1 year, 11 months ago by cjcampbell2000.
February 15, 2023 at 7:10 am #169118cjcampbell2000Participant
hi all im a complete novice with this h90 it has some great sounds. so I got a line 6 exp pedal which I’ve synced to h90 at least its showing 0-100 on pedal sweep however I’m trying to set up a normal wah wah but I’m not able to get it to act like a normal wah. it seems the bass\heel part of the sweep is getting stuck and then restarting the sweep from about a third of the way like bass mid then bass mid tre. instead of just bass mid tre through the sweep. if someone could share there normal wah settings id be so grateful thanks.
February 15, 2023 at 8:51 am #169120brockParticipant
From what I can find, the Line 6 EX-1 seems to have a 10K linear pot (good), but connects with a TS cable? You’re getting a full sweep, so you might be able to tweak the wah to what works for you, using the 2nd page of Parameter Mapping [6.4.1].
https://cdn.eventideaudio.com/manuals/h90/1.3.0/content/edit-modes/parameters.html#mapping
February 15, 2023 at 11:21 am #169128cjcampbell2000Participant
ahhhh so I have it connected with a TRS cable. i can’t find that setup page though thanks ill look further into this after work
February 17, 2023 at 9:31 am #169223cjcampbell2000Participant
thanks for your efforts I still can’t fully grasp this tho. I just can’t seem to resolve this wah issue. ill try with a normal cable instead of a TRS. I think I’m having issues understanding the menu system
February 17, 2023 at 10:38 am #169224brockParticipant
It may just be the Line6, but I don’t know, either way. The link I gave you up above is the final fine-tuning of the sweep range. You should be targeting the Manual parameter with expression, and also selecting Manual for the Shape parameter.
It will be easier if you use the Wah or Bass Wah as a Type. Depth & Q-Intensity (resonance) at maximum; Bottom at minimum. You can always adjust those down (or up) later on. In this use case, Speed doesn’t matter. For now, zero out all of the secondary controls (Depth Mod, Speed Mod, Mod Rate, Mod Source).
Depth (Bottom) and Manual targeting / the Parameter Mapping range seem to be the most critical adjustments for your issue. I would think you need to dial the Start up from 0 there.
What bothers me (from your OP description) is the ‘jumps’ seem similar to the Line6 acting like a volume pedal. But I’d like to think that’s not the case here.
February 18, 2023 at 5:20 am #169240cjcampbell2000Participant
hi, thanks again after 2 days of hair pulling I finally resolved the issue. in a nutshell it seems the actual lead I was using was faulty. it worked fine as a normal guitar audio lead but using it with ex pedal was causing the glitch. sooo my advice is double check your leads to avoid hours of menu surfing. thanks again for your help tho
February 18, 2023 at 8:40 am #169249brockParticipant
Frustrating, but I’m glad you got there. Seems to be a lot of that “bad cable” stuff going around. I’m guessing that many guitarists don’t have a lot of TRS cables lying around.
I’ve been there so many times, I can’t count them all. For years now, there is one of those cheap Behringer testers in every guitar case, and a few multimeters in my vehicle and my shop.
It’s the simplest things that junp up & bite you. Best part about airing them out at the forum is that might help the next person to avoid the same scenario.
February 18, 2023 at 1:36 pm #169261cjcampbell2000Participant
tell me about it. frustrating to say the least. I wish the menu was a bit simpler though id have found it much faster. anyhoo I’m back on the game. soooo thanks again
