Home › Forums › Products › Stompboxes › H90 Feature request: More more effects at once in the chain
- This topic has 15 replies, 11 voices, and was last updated 2 months, 1 week ago by
November 16, 2023 at 8:53 am #175811
I don’t need to have 4 reverbs or other complex algos, that’s not the intention of this post. But it would be very helpful if there could be some utility effects added into a chain to shape the sound even further in the box. Things I have in mind:
- LP/HP/BP 12/18/24/48 db Filter
- Parametric EQ
- Compressor
- Panorama adjustments
What do you think?
November 16, 2023 at 8:57 am #175812
I had this thought as well, but for a different purpose as I use a hybrid and would love to have 2 algo’s per path 1,2)
Even, if you could “bounce” an effect combination down to one opening up a spot for more it would kinda neat as well
November 18, 2023 at 12:35 am #175878
Related question: is there a way to see the DSP load? Maybe in the H90 Control app? What’s the most DSP-intensive algorithm?
December 8, 2023 at 7:55 am #176605
There is no way to see the DSP load of an algorithm since this is not necessary for the end user. The H90 is designed so it can run any combination of any 2 algorithms.
December 7, 2023 at 9:25 pm #176602
Any comment from the Eventide staff? 🙂
December 8, 2023 at 7:58 am #176606
Sorry for not responding sooner. These are great ideas, and we have discussed the option of some utility processors like this in the H90.
I can’t provide any sort of timeline for this, but if you have any suggestions for how you’d like to see these implemented, or any specific features, we’d be happy to hear your input.
December 8, 2023 at 8:46 am #176610
….LP/HP/BP 12/18/24/48 db Filter…
filters please.
December 13, 2023 at 12:19 pm #176730
I could fully understand that the UI/UX challenge is a reason why this has not be implemented yet.
I can see two spots where this could be implemented. I assume that two new of these sound shaping tools would be available.
1. As an add-on of each algorithm
On the last parameter page where in/out gain is located would be two new parameters:
- Shaping Tool: Would select the type of tool to be applied like 4 band EQ, Pan, Compressor, Gate.
- Position: Determines if the tool is applied before or after the effect.
Depending on the tool there would be a few more pages for the parameters. I see certain pros and cons:
+ Seamlessly blends into the existing menu structure.
+ Easily discoverable and accessible when doing sound design.– It should be part of an algorithm preset to keep UX simple and predictable but might not make always sense as such because it’s dependent of the whole effect chain.
– Re-position of the tool (eg. use it after algo two instead of before algo one in the chain) is cumbersome.
– The final amount of parameters can be big. There are algos which have 12 parameters and if a 4 band EQ with filters is selected as tool the total amount of parameters would be 30 spread over 10 pages.
– Adding more than one tool would make the menu a mess.2. As dedicated blocks in the routing chain
The routing menu would get two new pages before or after the insert configuration. Each page would consist of two static parameters which are similar to the one above:
- Type: Would select the type of tool to be applied like 4 band EQ, Pan, Compressor, Gate
- Position: Determines the position in the effect chain
Depending on which type would have been selected, additional parameters would be visible.
Pros and cons I see in this solution:
+ The blocks are independent from the effects which allows easier positioning and persistent state between preset/algorithm changes.
+ It’s a bit more logical
+ More sound shaping possibilities because more flexible placement (ie. affect inserts or one algo with two tools)– The menu structure and visual representation within the routing menu needs more rework compared to the solution above.
– Accessibility is not ideal because it’s a different menu not directly associated with sound design.
– Preset saving would only possible on the program level unless new paradigms for that would be introduced.What do you think? I’m very open to additions or different approaches.
December 7, 2023 at 9:56 pm #176603
I would kill for an EQ
December 12, 2023 at 3:26 pm #176705
A basic EQ and/or HP/LP filter utility would be incredibly helpful.
December 12, 2023 at 6:04 pm #176709
Yeah, its a pity the EQ has to take up one slot. A simple high pass & low pass in the pre section would be amazing.
The delays don’t have dampening or eq like Boss DD. The high end can tend to run away in the fx section – what about an H3000 mode that cuts from round 10k?
December 13, 2023 at 8:33 am #176717
I agree about with the global HP/LP filter in concept, but (playing devil’s advocate here) that may get doubled up / be redundant / cause confusion with the filters already present in the individual algorithms. But a multimode filter – automatable parameters – variable steepness – resonance option … now we’re talking.
As for the Boss DD part (I only have a retired DD-20 here) … I might be misunderstanding here, but I consider the H90 delay algorithms without a filter to be more the exception than the rule. The newer algorithms with many more exposed parameters, yes. No filter options.
December 13, 2023 at 10:37 am #176725
For the sake of simplicity, a 4 band PEQ with LPF/HPF/HSF/LSF options and adjustable steepness for the filters would fit all use cases on one module. Sometimes filters are cool for shaping a sound but it can also easily kill the character. Often it’s just about one or two frequency bands which need adjustment.
December 13, 2023 at 10:29 am #176723
Yeah, its a pity the EQ has to take up one slot. A simple high pass & low pass in the pre section would be amazing. The delays don’t have dampening or eq like Boss DD. The high end can tend to run away in the fx section – what about an H3000 mode that cuts from round 10k?
Some of the TimeFactor algorithms and MicroPitch have damping filters in the feedback section. If you need both a low cut and a high cut, the Vintage Delay algorithm is a dark horse as the filter knob has two filters running in the feedback loop; I find Vintage Delay with bits set to 11-13, depth set to 2, rate set to taste, and filter in the 25-45 range gets an ethereal float…
The tone knobs in delays that go +/- do cut up high if you turn the knob in the right direction. Look at Digital Delay and Mod Delay in particular (plus MicroPitch, which is more than just a detuner…). I also find that setting the mode on H910/H949 algorithm can be used to dial in the top end…
December 13, 2023 at 11:12 am #176726
Thank you! You 100% understand what I’m after; I reckon I just need to familiarize myself a bit better with all these algorithms.
BTW, I was referring to Boss’s latest DD-500; it allows eq adjustment in various places including the Feedback section & has customizable dampening eq shelves.
April 29, 2025 at 4:43 am #189828
It would be amazing to have an EQ (variable LP/HP) and a compressor as two inserts before the algos are hit. This would help so much! Another EQ after the algos would be another great plus. The EQ/Comp also is pretty much useless because it doesn’t have a lpf or hpf and a hpf is exactly what I would need. Best scenario: Input > EQ with HPF > Comp > Algos or H90 as is right now > output. Thank you!
