H90 footswitch issue after firmware
Home Forums Products Stompboxes H90 footswitch issue after firmware
    • #187165
      mike_99gsx
        This all happened after updating my H90 to the latest 1.9.8 this morning
        I use a 3rd party switch on EXP2 for switches 4,5, and 6
        Basically what is happening is that when I use the assignment of “INC + load” or “DEC + load” to any of the 3 switches then it just completely locks up the H90.  It still passes audio but literally no physical buttons do anything.  The PC connection (over USB or bluetooth also locks up.  If I reboot the H90 it will return to operational until I try hitting a foot switch for these parameters.  Here are things I have tried since this happened…
        1.) Resent the 1.9.8 firmware to the box (multiple times)
        2.) Removed the Apple OS software from my MacBook and reinstalled.
        3.) Tried a different TRS cable between the H90 and my switch
        4.) Tried EXP1 using switch 1, 2 and 3.
        5.) Moved other parameters to switch assignments without any issue.
        6.) Tried putting the H90 into recovery mode and sent the firmware again.
        At this point, I am stumped.  As I mentioned, it seems to be fine with any other parameters except the one I normally had assigned to switch 5/6 (INC + load/DEC + load)
        Any ideas would be welcomed.
      • #187167
        tsternfeld
          Hi, sorry you’re having trouble.  I can confirm this is a bug in 1.9.8.  We’ve reproduced it internally and will put a fix out ASAP.
          Thanks for pointing it out!
        • #187188
            H90 software 1.9.10 is now available and fixes this issue. Thanks again for reporting this.
