Home › Forums › Products › Stompboxes › H90 Footswitch wiring spa
- This topic has 15 replies, 6 voices, and was last updated 2 years, 3 months ago by
cellicello.
December 7, 2022 at 12:00 am #167466
Hi again Eventide, forgot to ask, I have a boss non latching footswitch which sadly does not seem to function with the H90 although it’s likely something I’m doing wrong……I quite sure I’ve selected the pedal correctly in the setting page (I want to tap temp), but I’m thinking maybe I should be using a trs cable (currently using a mono cable) to connect fs to h90 ? thanks
December 7, 2022 at 1:13 am #167469
Boss switches will not work. Please choose switches that function as normally open. It can be TRS or TS, doesn’t matter. TRS usually works with double or triple aux switches.
December 7, 2022 at 6:05 am #167485
<p style=”text-align: center;”>Just wanted to point out that many BOSS FS-type footswitches have a ‘polarity’ slide switch on the side, to select between NO & NC.</p>
December 9, 2022 at 11:51 pm #167549
Hi all, not having much luck with footswitches – any recommendations?
December 10, 2022 at 12:07 am #167550
AUX3E from Analog Endeavors
December 10, 2022 at 12:09 am #167551
Aux switches from Saturnworks
December 10, 2022 at 12:10 am #167552
American Loopers made a dedicated “H90” Aux switch
December 10, 2022 at 12:14 am #167553
Personally, I appreciate the artistry behind Bookmark Pedals. Just make sure you find one compatible with Eventide pedals. They made a switch with Panda images for me.
December 10, 2022 at 1:36 am #167554
Thanks everyone, i just need a tap switch and would rather just make one…. anyone know the specfication to wire this up ?
December 10, 2022 at 8:06 am #167555
This should do it: https://gtr1ab.wordpress.com/2012/09/22/footswitch-extention/
December 10, 2022 at 8:33 am #167556
Grab a soft touch momentary SPST footswitch and a mono 1/4 inch jack. Wire the ON pin to ring and the OFF pin to Tip.
December 10, 2022 at 10:50 am #167559
To use an external switch for tap tempo, you have to assign that function to that switch so the H90 to recognize it and know what to do. It may be that your current switch will work but you have not assigned it properly in the H90. I suggest you first make sure you have assigned that switch properly before making a new one. Follow the manual to do that. If you are unsure which aux switch will work, plug it in and try all of them until you get it. Restated, assign aux switch 1 and test. No worky? Assign aux switch 2 and test. Etc up to aux switch 6 until you get it.
If that does not work, you can make a one button switch/box. That is VERY easy to do.
You need a normally open momentary switch. Single pull single throw (spst).
A TS cord (two conductor – a signal (tip) conductor and a ground (sleeve) conductor – that’s a regular guitar cord) with a 1/4 inch plug.
If you are going to hardwire the cord to the switch in the box, solder the signal conductor to one of the two terminals of the switch. Then solder the ground conductor to the other terminal of the switch. There are only two terminals. There are only two wires. That’s it. No diodes needed for this one button switch.
If you want a 1/4 jack on your footswitch box, you obviously follow the same wiring steps to add that rather than hardwiring the cord directly to the switch.
Now plug that into the back of the H90 and follow the manual to program/assign that switch to perform tap tempo. As discussed above, if you are unsure which aux switch will work try all of them until you get it.
Good luck! You can do this!
December 10, 2022 at 11:57 am #167561
Or just use the Learn function when assigning the switch and let the H90 figure it out.
December 10, 2022 at 6:18 pm #167569
Thanks everyone, all sorted ! I made s simple tap tempo switch, and also had a spare boss non latching FS which also works perfectly. Once I used the H90 editor configure the settings things worked brilliantly.
December 10, 2022 at 7:13 pm #167570
Even better/great point.
January 8, 2023 at 7:38 pm #168369
I could use a Boss FS-7 and a DigiTech FX3 with the H90
