do you know how to apply fx B to fx A feedback loop?
For example I have delay line in fx A and i would like to add another fx B (pithchshif etc) but only to a feedback of delay fx A(or only to a wet signal of fx A) is it possible routing in H90?
I believe I understand. Using an Insert Mode Routing in Series:
Preset A – Delay
Mix = 100% wet
Feedback controls to taste.
Preset B – Pitch Shift (etc.)
Mix 100% wet
Pitch shift amounts to taste.
Program level
In Gain 50% (+/-) to balance between dry input and the combined delay feedback + pitched wet signal.
Please note that the pitchshifter will not be inside the delay feedback loop. It will do its pitch processing on the wet feedback as it exits the delay.
