H90 General Parameters only in software?
Home Forums Products Stompboxes H90 General Parameters only in software?
    • #176939
      winihh
      Every preset/effect in H90 has a second tab with general parameters in the software. I do not find those in the hardware… am I missing a hidden function?
      This tab has for example a bypass in/off that can be assigned to an expression pedal. …and much more.
    • #176944
      You may not be dialing the Select Knob far enough (clockwise).  Or when you first touch the Parameters LED button, dial it to the left (CCW).
      https://cdn.eventideaudio.com/manuals/h90/1.7.1/content/edit-modes/parameters.html
    • #176945
      winihh
      I was confused 😉
      The only difference is Bypass on/off
      Thanks!!!
