Total NOOB question here. So when you alter a program you made yourself and you accidentally change a preset inside it and the asterisks is now on the program you made with the new (accidental) preset, how do you switch it back to the original program you made?
On the pedal itself, as long as you haven’t saved the bad changes, you may simply navigate away from the current program and then come back to it; you will return to the Program in the state it was last saved. If you did accidentally store changes there isn’t a way to restore the previous settings.
Oh my God, that worked. How simple. Previously, I was navigating to another program but not actually SELECTING it. When I did that and went back to the program in question, the original settings I made were there. Thanks for your help!
