H90 Insert kill dry ?
Home Forums Products Stompboxes H90 Insert kill dry ?
    • #185965
      cliveluis
      Hi
      a question ?
      when to connect another pedal into H90’s inserts do you use kill dry option ?
      for example if I am using strymon pedal , or H9 , do you enable kill dry on those pedals?
    • #185969
      This depends on a lot of things, like which effects are being used as the insert and where the insert is placed in the signal path of the H90.
      If you are using a delay or reverb effect as your insert, and your dry signal is already present using the H90’s Program or algorithm mix parameters, then yes, you can turn kill dry on so you only get the wet signal from the insert.
