H90 Insert Routing Question with modeller
Home Forums Products Stompboxes H90 Insert Routing Question with modeller
    • #189214
      tomclark1989
        Hi guys,
        I currently use my H90 with an FM9, running the H90 into Output 3 of the FM9 in stereo. Ideally I’d like to use Pre/Post or Insert mode on the H90 so I can use effects both pre and post amp in the FM9. I think Joe on the Facebook forum told me how to do it but I can’t find my post anymore – is there a way that I can use Insert mode on the H90 while still using the outputs of the FM9 to run to FoH/IEM/Cabs?
        Cheers!
      • #189227
          All of the routing options are detailed here (thanks to Joe!) https://youtu.be/0G_WtfUatSc?si=XArjLvGeYAOBcfno&t=460
