H90 – Insert Send/Return on the Global Mapping
Home Forums Products Stompboxes H90 – Insert Send/Return on the Global Mapping
Viewing 0 reply threads
    • #170490
      Lodeman
      Hi!
      I’m using a Delay/Reverb Inserted on the H90.
      It would be great if we have INSERT SEND/RETURN levels available on the Global Mapping.
      Depending on insert routing used, I cannot “SWEEL” the inserted reverb/delay.
      This is possible only when Insert is AFTER A,B or AB by using “A/B OUT GAIN”.
      If availble on the global mapping, I could just use the parameter INSERT SEND LEVEL assigned to expression pedal and it is done!
      I hope this is valid and doable request for future implementations .
      Thanks.
