H90 Instant Warp Delay Feedback (Like Strymon Timeline)
Home Forums Products Stompboxes H90 Instant Warp Delay Feedback (Like Strymon Timeline)
Viewing 6 reply threads
    • #187894
      jessey_o
        Hi everyone,
        I’m a new user of the H90 and I’m trying to find a way to active a feedback loop with my delays just by pressing one of the footswtiches (Just like the Strymon Timeline)
        I know I can do something similar with Hot Switches but it’s not exactly what I’m looking. I actually wanna do the exact same thing than with a Strymon Timeline
        Thanks for helping!
        Jessy
      • #187897
          I’m not exactly sure what effect you are looking for.
          Bouquet Delay has a self osc (feedback) perform parameter, is that what you are looking for?
        • #187898
          jessey_o
            Hey thanks for helping,
            On the Strymon Timeline, you can just instant press with your foot on preset A or B (Depending which one your currently using) and it automatically active a feedback loop. Is the only way to achieve that with the H90 is to use the Hot Switch fonction? Or is there another way (Just like the instant phaser/flanger) to activate a feedback look by holding the footswitch with your foot.
            I hope this is clear! Let me know!
            Jessy
          • #187899
              Try the self oscillation perform parameter of Bouquet Delay. Other delay algorithms also have similar perform parameters.
            • #187904
              watson01
                Hi everyone, I’m a new user of the H90 and I’m trying to find a way to active a feedback loop with my delays just by pressing one of the footswtiches (Just like the Strymon Timeline) I know I can do something similar with Hot Switches but it’s not exactly what I’m looking. I actually wanna do the exact same thing than with a Strymon Timeline Thanks for helping! Jessy
                Hi Jessy,
                You can achieve a similar feedback loop with the H90 by setting up a Hot Switch with a longer delay time and engaging it in real-time. While it’s not identical to the Strymon Timeline, experimenting with delay settings might help you get closer!
                Hope this helps!
              • #187919
                Dirtykeys
                  It’s incorrect words. That’s why you aren’t getting the response you want.
                  OP wants to be able to step on a hot switch… engaging a Delays feedback.
                  ”warping” has nothing to do with a Timeline or the Eventide. Just a catch phrase they got caught up it.
                • #187924
                    It’s incorrect words. That’s why you aren’t getting the response you want. OP wants to be able to step on a hot switch… engaging a Delays feedback. ”warping” has nothing to do with a Timeline or the Eventide. Just a catch phrase they got caught up it.
                    Calling it a ‘warp’ function might be a leftover from the confusingly named Boss DD-20 modes.
                    I took this as the OP is looking for an additional function for the per-Preset Active / Bypass switches:  Tap for Act/Byp, and hold the switch to kick in infinite repeat.  Which isn’t possible, and I don’t believe there to be a direct workaround for it.
                    I can think of a couple of ways to simulate it.  Probably involving alternate Program Changes, or MIX + Feedback mapped to a HotSwitch; with two closely related delay instances in Parallel, that sort of thing.  But I do think the closest answer is still going to involve the aforementioned Performance parameters, REPEAT (M), or some combination of HotSwitch mappings.
