H90 Looper Arbitrary Ending
Home Forums Products Stompboxes H90 Looper Arbitrary Ending
Viewing 3 reply threads
    • #167383
      frankie138
        I am having an issue where the H90 looper stops recording at a (seemingly) arbitrary time eg: Max length is set to 64, but the looper stops recording (and begins looping) at measure 42, though it seems to occur at any max length.
        The Looper is synced to 120 bpm midi clock (coming from an MPC), and recording at 1x in this case.
        No other midi is being  sent to the H90 besides clock.
        Any insight would be much appreciated, thanks.
      • #167498
          Sorry for the late response, we’re looking into this issue. Thanks for your patience.
        • #184552
          gregbob
            Hello.  I’m having the same issue nearly two years later.   MIDI clock or seconds, the looper stops at some arbitrary point.   Not consistent, either.
            I also get very loud popping sounds on play, but that might be the result of the arbitrary ending.    Let’s solve problem 1 first.
            Software version 1.8.6.72.
            Any updates or advice?
          • #184812
            JDrage
              I tried the Looper presets for the first time today and ran into this too.
              I was using the Basic Looper preset from the library and after recording a loop there were some very loud crackling sounds during playback, only in the right channel, and only during part of the recorded loop. I also couldn’t get it to overdub–the 1-Button Looper switch was not putting the looper into Dub mode. There were other strange things, like even while stopped I could not change the maximum record time. I came back later to try to figure it out and it was working normally. I couldn’t get it to happen again.
