h90 looper control delay
Home Forums Products Stompboxes h90 looper control delay
Viewing 4 reply threads
    • #182580
      danperfect
      Hi
      I am using a Morningstar MC8 to control the looper functions on the H90, all works as expected, but there is a small delay after pressing the footswitch when recording that truncates the first transient. This is not the case when using the inbuilt footswitch, but I need floor control – so, is this what others have found, and will a 3 button external switch give me the record start without the short pause?
    • #182585
      Quick question: Have you tried setting up Looper Mode for that MC8 switch action, or set the overall Switch Sensitivity to 5?
    • #182586
      danperfect
      Hi
      thanks for the reply – not sure what you mean – the MC8 is sending CC midi messages to the H90 to control the looper functions.  Are you suggesting another way?
    • #182588
      I was.  Sorry if that was unclear.  I assume your MC8 features are the same as the MC6 Pro here.  My suggestion was to set the transmitting MC8 switch at maximum sensitivity.  Then use that as a diagnostic to determine if the small delay is on the MC8 controller end, or on the H90’s reception of that MIDI CC.
      https://manuals.morningstar.io/mc-midi-controller/Looper-Mode-for-Zero-latency-Looper-Control.186155011.html
      I guess it could also be caused by a lot of unrelated MIDI messages being transmitted ‘simultaneously’ (serially) by the same switch.  As the MC6 Pro can transmit up to 32, it’s worth mentioning as another possible cause.
    • #182589
      fiddlercrabseason
      Also worth asking…  Do you have tempo sync enabled on the H90 Looper preset?
      https://cdn.eventideaudio.com/manuals/h90/1.8.6/content/algorithms/looper.html
      “…Tempo Sync Footswitch Quantization
      MIDI Clock is made up of a series 24 “ticks” per beat. Tempo Sync quantizes many of the Footswitch actions either to the next MIDI beat or the next MIDI tick...”
