H90 Looper play speed glitch
Home Forums Products Stompboxes H90 Looper play speed glitch
    • #175636
      vvarvel
      Having a little trouble with using the Quick Knobs to control the play speed on the looper.  When the resolution is in Octaves, the knobs are very erratic in selecting the speeds—very short turn between 2x, 1x, 1/4x, then very long turns(sometimes more than 2 turns)to get to -1/4, -1/2, etc…..Then, when resolution is set to Smooth, it always jumps immediately from 100 to 112 or 113, then I can move smoothly.  I’m pretty sure I don’t have speed assigned to more than one controller option.  Any thoughts about this?
    • #175639
      fiddlercrabseason
      <p>
      …when resolution is set to Smooth, it always jumps immediately from 100 to 112 or 113, then I can move smoothly. I’m pretty sure I don’t have speed assigned to more than one controller option…
      The speed snapping to 112/113 when resolution is changed (smooth, chromatic, etc.) is a confirmed bug.
