Home › Forums › Products › Stompboxes › H90 looper playback speed varies/jumps
- This topic has 8 replies, 2 voices, and was last updated 2 years, 10 months ago by
Reddy_Kilowatt.
November 12, 2023 at 1:04 pm #175651
I’ve experienced an apparent bug where the playback speed of a loop varies.
Conditions: Tempo Sync ON; Max Loop Lenth 8 beats; tempo set to same bpm as drum machine/metronome; for my test I played simple palm-muted 1/4 notes to the drum machine/metronome. After only a few times through the loop, there is clear evidence that the playback has drifted from the original tempo (I’ve observed playback to lag). Further, it doesn’t seem like the playback speed is consistent through the loop, as individual quarter notes may be fast or slow.
User error is always a possibility, so if I’m doing something wrong, please let me know. Otherwise, if it’s a bug, knowing that would be helpful also.
November 13, 2023 at 10:43 am #175677
What version of the firmware are you running on the pedal?
November 13, 2023 at 11:11 am #175681
1.5.7.220
November 13, 2023 at 11:13 am #175683
Is your Metronome connected to the H90 via DIN MIDI? Is the Clock Source in the System menu set to DIN? In the TEMPO menu, is Source set to MIDI Clock?
November 13, 2023 at 11:19 am #175684
No, the metronome isn’t connected to the H90 at all. Each device (metronome & H90) is using its own clock.
EDIT: to be clear, this isn’t a case where the metronome and H90 clocks are ever so slightly off and the discrepancy between them gradually grows. It happens almost immediately, and even if you turned off the metronome, the timing issues would still be clearly audible.
November 16, 2023 at 6:07 pm #175837
Adding info from this afternoon’s experimentation… while I still think my originally reported issue is a genuine problem, I’ll note that the behavior does NOT occur when I feed the metronome (Singular Sound Beat Buddy) clock to the H90.
November 17, 2023 at 7:42 pm #175863
Another observation… the transport display on the 1-button looper has an issue. I have an 8 beat loop repeating. The transport counts through beats 1 through 7 correctly, but at beat 8 it displays beat 1 for 2 beats. So 1 2 3 4 5 6 7 1 1 2 3 4 5 6 7 1 1 2 3 4 5 6 7 1 1 and so forth. I think it’s remaining synched with the Beat Buddy clock for playback, but the display isn’t correct.
November 19, 2023 at 2:02 pm #175901
Adding to this… it seems like the Loop Play-Length is getting confused. For example, with an 8 beat Loop Length (recorded with Loop Max-Length at 8 beats and allowed to record all the way through and autoclose the loop), the Loop Play-Length will commonly change itself down to 7 beats. This isn’t specific to 8 beat loops… I’ve seen it with 16, 32, etc.
November 19, 2023 at 2:05 pm #175902
And while I’m at it, the Quick Knob behavior for Speed is really bad. You have to turn it a LOT to get from 100 to -100 and a lot of the rotation doesn’t do anything.
