Home › Forums › Products › Stompboxes › H90 Looper REC / PLAYBACK Speed
- This topic has 2 replies, 3 voices, and was last updated 18 hours, 15 minutes ago by
joecozzi
Eventide Staff.
April 17, 2025 at 5:44 pm #189616
In Performance Mode, what is the best method to record a loop at normal speed, and then have the playback speed assigned to the Hot Knob so that you can increase OR decrease the speed?
Currently I have a Looper set to – Max Length: 60 Sec / Rec Speed: 2X / Resolution: Smooth / Play Speed: 200 . (The Play Speed Ctl Source is set to Hot Knob P)
After I hit REC and then PLAY on the foot switches, the HK P reads 100 and I can slow down the loop by reducing that number, but I cannot speed up the loop.
I have tried setting the record speed to X1 but this just yields a faster playback speed at HK 100. Setting the Play Speed lower just yields a slower initial playback speed.
I am searching for the setting that will record and playback at real time speed then allow the HK to start at a center point that will allow you to speed up or slow down from real time.
Running 1.9.11.211
April 18, 2025 at 10:29 am #189620
I think I see where you’re going with this, but I’m not in front of the Looper to confirm it. So, from memory, something to try out:
- Max Length: 120 Sec / Rec Speed: 1X / Resolution: Smooth
- Bind the full range of Play Speed to HotKnob P as your control source.
- Dial HotKnob P to Play Speed = 100.
A return-to-center control (like Pitch Wheel) would be ideal for this, if that was supported. It might be difficult to hold position at 100 with an EXP pedal & smooth resolution. But it illustrates the option of external control over HotKnob P, which in turn will control the Play Speed.
April 18, 2025 at 10:44 am #189622
In Performance Mode, what is the best method to record a loop at normal speed, and then have the playback speed assigned to the Hot Knob so that you can increase OR decrease the speed? Currently I have a Looper set to – Max Length: 60 Sec / Rec Speed: 2X / Resolution: Smooth / Play Speed: 200.
With Play Speed set to 200, which is maxed out, there is no way for the playback speed to go faster. For this to work, I would set Play Speed to 100, which is the normal starting off point for a basic loop. I would set your record speed to 1X. You will need to readjust your Max Length back to 60 sec. (because adjusting the Rec Speed changes the length).
Because a parameter like Play Speed has an unusual range of values from -200 to paused to 200, I would not recommend using the Hotknob to control it. Use a Quick Knob assigned to Play Speed and you will find you can go in any direction and with more precision.
