Home › Forums › Products › Stompboxes › H90 Looper transport problem
- This topic has 29 replies, 9 voices, and was last updated 1 year, 9 months ago by
Eventide Staff.
November 19, 2022 at 3:16 pm #166861
I’m noticing that my H90 (original OS version – not yet updated) has difficulty looping cleanly – it seems to flub the beginning of the recording, sometimes affecting the loop timing and sometimes just omitting the first note even when the timing is correct. This appears to happen regardless of whether I’m using the on-device 1-button looper switch or the Record command mapped to a 3-button aux switch (I haven’t tried it with MIDI). Tempo is off on the Looper algorithm. I’d chalk it up to operator error, but I don’t have a problem punching in and out cleanly in SOS mode on my Volante. Any suggestions? (Really hoping this is a known bug that will go away if I update the device!)
November 30, 2022 at 1:26 pm #167332
Any suggestions on this? Updating to the latest firmware did not correct the problem.
November 30, 2022 at 8:22 pm #167343
I’m going to take a wild stab at this; no doubt you have already eliminated the usual suspects. But I noticed having similar aux switch / looper issues at the start. Turns out the parameters were triggering on (momentary switch) release.
Aux switches that I’ve always used elsewhere; never adjusted the options (intentionally). I use a pair of Boss FS-6s. Flipped the polarity switches, and that’s what it was. Momentary on switch press.
I’m not projecting that as your issue there. Something I ran into myself.
November 30, 2022 at 8:29 pm #167344
I’m going to take a wild stab at this; no doubt you have already eliminated the usual suspects. But I noticed having similar aux switch / looper issues at the start. Turns out the parameters were triggering on (momentary switch) release. Aux switches that I’ve always used elsewhere; never adjusted the options (intentionally). I use a pair of Boss FS-6s. Flipped the polarity switches, and that’s what it was. Momentary on switch press. I’m not projecting that as your issue there. Something I ran into myself.
An interesting observation. I don’t think it’s causing my issue, though, because I’m having the same problem with the onboard switches. Calibrating the aux switch also shows the appropriate triggers lighting up on press, not release.
January 10, 2023 at 8:29 pm #168412
Hi coirbidh_99
Did the update solve your issues?
January 13, 2023 at 1:25 pm #168448
Apologies – with one thing and another, I haven’t had a chance to give the new update a proper run-through. I’ll report back this weekend. Appreciate the check-in!
January 13, 2023 at 2:02 pm #168451
coirbidh_99, Actually, we are still working to resolve the looper issue. Please stay tuned for an update. I’ll post it here when it has been resolved.
January 24, 2023 at 7:34 pm #168632
I just booted up, and noticed the 1.3.0 update available. Release notes indicate 1-button looper improvements on rec/play transition, DynaVerb Omni, and other fixes. About to check it out myself.
January 26, 2023 at 2:33 am #168682
I don’t see 1.3.0. Is this a beta release?
January 26, 2023 at 2:40 am #168683
Yes, this is technically a release for beta testers. Will be publicly available soon.
January 31, 2023 at 6:17 pm #168786
The 1.3 update seems to have done the trick, at least as far as the 1-button looper is concerned – I haven’t tried mapping the aux switches yet. Thanks for getting on this!
January 31, 2023 at 6:23 pm #168787
Thank you for reporting back.
March 16, 2023 at 9:31 pm #169786
Joecozzi. Any update to the looper. My problem is that when I assign a midi cc to that button and make it as a one looper it may work for a loop, but then stop working and reset the buttons function to the standard. Is this still in the works for being fixed? Thanks!
March 17, 2023 at 9:52 am #169796
Sorry, it’s not quite clear what the issue you are having is, and this doesn’t seem to be the same thing as the original issue reported.
Can you provide step-by-step instructions to reproduce the issue you are having?
March 17, 2023 at 11:42 am #169799
Sorry, it’s not quite clear what the issue you are having is, and this doesn’t seem to be the same thing as the original issue reported. Can you provide step-by-step instructions to reproduce the issue you are having?
no problem. This happened when using the app or on the pedal. I’ll tell you when assigning on the app. I add the basic loop to my pedal. I have the clock responding to midi to sync with my other pedals. When I assign the button (a or b depending on which side I added the effect) to trigger the 1-step function so I can start/stop/erase with one pedal using the Morningstar for midi. I’ve tried both the assigning of the cc number and the midi learn. From there it seems to work for maybe one loop then it gets reset to act/byp for that button. What am I doing wrong and let me if you have any other questions.
March 20, 2023 at 10:45 am #169831
Thanks for providing these instructions, but I can’t seem to reproduce this. When I assign a MIDI CC to control the 1-button looper, the mapping will remain after I have started/stopped the loop a few times.
If you could record a video of this issue and email it to support@eventide.com that would be helpful.
March 20, 2023 at 11:43 am #169835
… This happened when using the app or on the pedal. I’ll tell you when assigning on the app. I add the basic loop to my pedal. I have the clock responding to midi to sync with my other pedals. When I assign the button (a or b depending on which side I added the effect) to trigger the 1-step function so I can start/stop/erase with one pedal using the Morningstar for midi. I’ve tried both the assigning of the cc number and the midi learn. From there it seems to work for maybe one loop then it gets reset to act/byp for that button. What am I doing wrong and let me if you have any other questions.
I was working on something similar this past weekend. I couldn’t reproduce the issue, either.
Any chance you can hook up the Morningstar to a MIDI Monitor? From an outsider’s POV, it seems to me like the Morningstar might be transmitting some additional MIDI messages?
Just a guess, but I’d check the Global MIDI or other Program assignments in the H90, especially the various Act/Byp & HS parameters. I’ve gotten nailed (inadvertently, more than once) by LEARN with an intermittent CC#0 Bank Change from an S/A Reflex, or upstream synth.
May 26, 2023 at 4:57 pm #171554
I am not clear as to how I can loop with h90 . Do I need an external pedal to trigger the loop recording function or can I assign one of the switches ? The manual is not clear on how to loop or it could just be me 🙂
May 26, 2023 at 5:07 pm #171556
The easiest way is to go into PERFORM mode and assign the “1-Button Looper” option to a footswitch:
Press once to record
Press again to play the loop
Press and hold to undo/redo
Double tap to stop playback
While the loop is stopped, press and hold to empty the loop.You may also assign individual looper functions like Record, Play, Stop, Empty and UNDO/REDO to a footswitch in PERFORM mode. For these it’s best to assign them to an external aux switch or MIDI controller.
December 9, 2024 at 5:06 pm #186787
it seems to be impossible to assign individual looper functions like Record, Play, Stop, Empty and UNDO/REDO to a footswitch in PERFORM mode because these functions are on a special perform page that is dedicated to the most useful Looper transport parameters. These footswitches cannot be remapped. so how we assign them directly?
December 9, 2024 at 5:11 pm #186788
If the looper is loaded into Slot A, press the A LED button to cycle through the options. Only 1 option may be selected. You can use the dedicated looper page to access more than 1 option.
To map the parameters to MIDI controllers or aux switched:
Press and hold any of the LED buttons (P/A/B) and this will open the Performance Parameter Mapping menu.
Use Quick Knob 1 to select a parameter (example: Record) and use Quick Knob 2 to select a control source (example: CC1)
Now, CC1 will toggle the record function.
May 26, 2023 at 5:10 pm #171557
Do i need an external foot switch to loop or can I use the h90 pedal ?
May 26, 2023 at 5:21 pm #171558
You may use the H90 pedal. As I explained above, the easiest way to loop is assign the looper algorithm to a side and go into PERFORM mode. Assign the 1-button looper to the corresponding footswitch.
May 26, 2023 at 5:48 pm #171561
Where do I find the 1-button looper ?
May 27, 2023 at 7:20 am #171566
It’s a Performance switch option. Check the manual if you aren’t sure how to assign switch functions in PERFORM mode.
June 3, 2023 at 7:31 pm #171718
This took me quite a while to figure out as well. When you have the Basic Looper program loaded, the Looper is in the A slot. Press PERFORM. Since the middle of the three switches is mapped to the A slot, that’s the one you switch to 1-Button Looper. To do that, press the LED-backlit button just above the button to cycle through functions. Eventually you will get to 1-Button Looper.
December 11, 2024 at 7:34 am #186811
HERE IS MY PROBLEM WITH MY MORNINGSTAR MC6 PRO:
I think I know how to assign CC#, but each time I assign CC# in the looper of the H90, the looper stops to work.
I press and hold any of the LED buttons (P/A/B) in PERFORM MODE in the 3thrd page where you can fin REC, PLAY and STOP.I assign for example:
CC50 REC
CC51 PLAY
CC52 STOP
CC53 undo/redo
CC54 ERASE
with the learn function in the H90
but after that, I can not use the looper, even directly with the foot switch of the H90… that’s crazy-
December 11, 2024 at 9:04 am #186813
On your MIDI controller make sure you are assigning release actions for the REC, STOP, and Undo/Redo commands.
For example, your assignments should look like this:CC50 REC
Msg1, Action:Press, CC#50, Value 127
Msg2, Action: Release, CC#50, Value 0CC52 STOP
Msg1, Action: Press, CC#50, Value 127
Msg2, Action: Release, CC#50, Value 0CC53 Undo/Redo
Msg2, Action: Release, CC#50, Value 0The reason you must do this is because the H90 is expecting similar behavior to momentary normally open switches.
December 12, 2024 at 9:04 am #186841
HELLO,
That works if I use looper in tempo mode OFF,
but if I try to switch to tempo mode ON, with midi clock synchro, nothing works…
I mean, even the looper with H90 foot switches stop to work once I select tempo mode ON…
do you know why?-
December 12, 2024 at 9:36 am #186842
If the H90 is set to receive MIDI clock, but there is no MIDI clock being sent to the input, the looper transport will not function.
Please try going to the H90 tempo menu (press and hold Presets + Parameters) and make sure the Source is set to MIDI Clock.
If you stay on this menu, when you send MIDI clock to the H90 you should see the Tempo parameter update. If you change the BPM of the MIDI clock you are sending, you should see the H90 Tempo follow the BPM.
