Home › Forums › Products › Stompboxes › H90 loud hiss and hum
- This topic has 37 replies, 12 voices, and was last updated 10 months ago by
ccampagna.
February 28, 2023 at 10:06 am #169448
Just got my H90 and out of the box there is a noise floor on all programs/presets that makes it unusable. I sounds like a ground buzz with a loud shhhhhh whenever audio is engaged. Using the factory power supply, I’ve tried multiple cable swaps and power outlets, guitar strait in to H90 and out to amp, tweaked parameters, mix, gate, in/out gain to no avail. I have other digital pedals that run on the board with no issues. I’ve owned the H9 and a few other Eventide delays, but never had this problem with any of those. At this point I feel pretty certain it may just be a defective unit and return it to the retailer for a replacement. Any other recommendations?
February 28, 2023 at 10:22 am #169449
Please contact support@eventide.com for the best troubleshooting. If they determine there is in fact a problem, they will be able to take care of you directly.
March 4, 2023 at 7:11 am #169540
5 days no response from support. Sending it back to the retailer to exchange for another unit
March 4, 2023 at 7:37 am #169541
Hi pb4567string,
This very odd. When you emailed support, did you get an email verifying that the message was received?
March 4, 2023 at 10:33 am #169549
I did not receive a verification email. I will try again. Thank you
March 4, 2023 at 10:38 am #169550
Ok just sent another request and the verification email popped up this time. I look forward to their assessment. Thank you for the info Joe!
May 28, 2023 at 10:10 am #171603
I have this problem too. For example, the ground hum is loud enough that all pitch programs play an audible chord in the background; they are harmonising the hum – not hugely loud but enough to make the unit unusable. I tried an alternative PSU and it is the same. I have used Eventide products for 20 years and know this can’t be right. I should just return this unit, right?
May 28, 2023 at 10:10 am #171604
Did you resolve it pb4567string?
August 19, 2023 at 3:10 pm #173478
I have the same problem. The hum <span style=”font-size: inherit;”>is louder with the H90 power supply. Using using one of the Eventide power units. The hiss is different from program to program. I imported some programs I wrote from my H9 and the H90 added more noise. </span>
August 21, 2023 at 9:54 am #173497
Do you have USB hooked up to the pedal while you’re playing it? Also, can you describe your signal flow? Do you have any other pedals in the chain? Are you going straight into the amp, etc?
August 25, 2023 at 12:20 pm #173630
This is why it is imperative to unlock the Bluetooth feature!
August 25, 2023 at 12:45 pm #173631
The noise is louder with the usb. I find it manageable when using my laptop instead of my desktop. Also choosing the correct input/output settings helps
August 26, 2023 at 6:03 pm #173644
This is what I hear.
00:00:00 Amp no fx with loop: -28.1 dbfs
00:13:50 H90 no usb -17.8 dbfs
00:27:00 H90 usb -4.5 dbfs
00:40:00 H90 usb short cables -5.8 dbfs
00:53:50 Tc flashback no usb -23.3 dbfs
01:07:00 Tc flashback usb -22.9 dbfs
https://1drv.ms/f/s!Aj7QIcC9IL33hK4TWXku2qw29jvG1A?e=Vu44ZQ
Tried everything, other cables, everything in the same socket, after a powerconditioner, without powerconditioner. Changed IO, bypass, killdry settings in H90.
Guitar->H90 input1
H 90 output1->Duotone H&K input
DuotoneH&K send->H90 input3
H90 output3->DuotoneH&K return
It’s a parallel loop and the amptone is kind off classic rock(no shitload of gain)
How can I fix this? Or is this a faulty unit??
August 28, 2023 at 3:21 pm #173703
Ok, just tried the H90 only in the loop of the amp, and the noise and hiss are almost gone. Input 3- output3.
But I need dual mode for whammy-wah-octaver and other pre stuff.
Seems to me that there is a problem with the unit when it’s in dual mode and in the parallel loop of a distorted tube amp…..
Or am I doing something wrong?
August 31, 2023 at 9:43 am #173923
Seems to me that there is a problem with the unit when it’s in dual mode and in the parallel loop of a distorted tube amp….. Or am I doing something wrong?
Can you describe the problem or are you still referring to noise when using USB?
When using H90 in any amp with a parallel loop, the H90 needs to be used in Kill Dry mode to avoid any type of comb-filtering. If the amps effects loop has a dry/wet balance control, it’s preferred to make it function as a serial loop by setting to 100% wet. Then, you’ll be able to use the H90 without Kill Dry on.
August 31, 2023 at 1:54 pm #173931
Hello Joe,thanks for your responce.
The H90 is in Global Kill dry mode, the amps loop has a dry/wet balance but 100% is
still parallel! It’s not possible to make it serial.
There is a 50Hz noise when the H90 (in dual mode) is connected like this:
Guitar->H90 input1
In the amps clean mode it’s not a problem.
In overdrive mode it’s a lot worse,
and in boost mode it’s almost unusable.
When I connect usb then it’s only usable in clean mode! I’ve made recordings off the noise.
But when I put the H90 only in the parallel loop there’s no 50Hz noise, and almost no usb noise, but then I can’t use Whammy, Octaver, Wah, Weedwacker…….
August 31, 2023 at 2:16 pm #173932
the amps loop has a dry/wet balance but 100% is still parallel! It’s not possible to make it serial.
It’s possible that effects loop functions differently than other amps with balance control. ENGL amps, for example, have a balance control and 100% generates a serial FX loop according to the manual.
There is a 50Hz noise when the H90 (in dual mode) is connected like this: Guitar->H90 input1 H 90 output1->Duotone H&K input DuotoneH&K send->H90 input3 H90 output3->DuotoneH&K return In the amps clean mode it’s not a problem.
This specific frequency is indicative of a ground loop in the system. You can try placing an isolation transformer in between the amp’s FX send and the H90 and the H90 Out to the effects loop return. It’s possible only one of these will solve the issue.
August 31, 2023 at 10:34 pm #173939
Should this do the trick?
August 31, 2023 at 11:32 pm #173959
Yes, that is a great option especially because it can be used for two channels.
September 18, 2023 at 2:58 pm #174222
Well, I just received my isolation transformer. I put it in the chain like you said but it didn’t work : “This specific frequency is indicative of a ground loop in the system. You can try placing an isolation transformer in between the amp’s FX send and the H90 and the H90 Out to the effects loop return. It’s possible only one of these will solve the issue.”
Luckily it worked when I put it before the amp input and with a groundlift.
Does this make sense to you, and is it safe?
September 18, 2023 at 3:04 pm #174223
Yes, it perfectly fine. Ground loops are a challenge to track down. Glad you solved the issue.
November 9, 2023 at 10:43 am #175561
I’ve noticed a slightly different noise issue. It only occurs when I connect the H90 to my MacBook Pro via USB to use the H90 Control App. As soon as I connect the cable, I get a noticeable amount of “computer noise” coming through my Scarlett 4i4 audio interface (same issue with my Scarlett 2i2). This is not 60Hz ground hum. It sounds like it’s a function of what the H90 processors are doing… kind of like if you float your cellphone over your guitar pickups. As I navigate through through the H90 Control App, that pattern of noise varies slightly. I’ve tried a couple of different US cables… same issue. Any ideas? Is there a USB “isolation” device?
November 9, 2023 at 10:53 am #175562
Hi garyslama,
This interference is common with USB cables, unfortunately. I have heard people say that a 3rd party cable with a ferrite choke or clip-on EMI noise filter may help to mitigate this problem but I have not tested this.
November 25, 2023 at 10:54 am #176109
Tried a USB-C cable with ferrite chokes on both ends… no change in the noise level.
But…
Just saw that Eventide is going to be supporting Bluetooth connectivity, so… problem solved!
Thank you, Eventide!
On Monday, November 27th, Eventide will be making a public beta of firmware providing Bluetooth functionality to the H90. By installing Application Firmware version 1.7.1 (Beta) via H90 Control, users will be able to pair to their pedals to MacOS computers as well as Apple iPads to control the H90 wirelessly using the app.
January 16, 2024 at 1:08 am #177313
Mine just started to do this with the USB cable plugged in too. Even in bypass mode it’s just a noise generator & not usable. I need to have the USB for clock sync.
It doesn’t really make sense why considering that no audio is passing thru the USB cable & the unit is being powered by a power supply.
With a highest quality USB-C cable direct into a macbook this unit should be DEAD quiet. Never have I ever had any USB problem ever like this even with really inexpensive gear.
Are we sure there just isn’t a problem with the USB ports on these units?
January 16, 2024 at 10:21 am #177407
Have you changed anything else in your setup? Perhaps you have relocated where some devices are and connected things differently?
USB ground loops are common with many devices, not just the H90. The best thing you can do is try having all of your gear powered from the same outlet.
March 9, 2024 at 11:17 pm #179041
The output as well as the hum both got louder with the current update.
March 11, 2024 at 9:10 am #179137
Sorry, it’s not clear what the issue you are reporting is.
Is the noise you mention only an issue when you are connected to a computer using USB?
Which firmware is installed on your H90?
It would be best to contact support@eventide.com if you’d like to pursue this further.
April 29, 2024 at 5:34 pm #181665
Hi, I just recently purchased an H90 and I find there is hum and phasing noise when I use the flange or and rotary algorithm or delays. Ive tried it in the FX loop. Straight in the amp, with and without distortion, (both before and after the H90) . I have an H9 ive been using for quite some time and its dead quiet even with distortion. I updated the software, reset the factory presets. Im at a loss here. Any input would help.
Thanks
Anthony
April 29, 2024 at 5:43 pm #181666
My issue ending up coming from a non-powered USB hub that wasn’t even in the chain.
But ideally you want all your gear to have the same ground or you’ll get this problem.
I still feel there is a design issue as no audio passes thru the USB – seems like some kind of isolator is missing.
April 29, 2024 at 5:46 pm #181667
moreigloos I have everything coming from a great power sully on my board. Still noise. Scratching my head at this point.
April 29, 2024 at 6:32 pm #181669
Sorry to hear you are having issues.
Can you please contact support@eventide.com and provide a video that shows the noise you are experiencing?
It would be best if you can use a simple setup, such as a guitar > H90 > amp with nothing else in the chain. If the issue is only with certain algorithms, it would help if you could show this as well.
April 30, 2024 at 5:11 pm #181729
Oh boy, the hum is out of control on my H90, making it unusable. I’m simply running In 1 and Out 1 to the FX Send and Return of my Mezzabarba Skill 30 combo. Other delay units I’ve plugged into the FX Loop (Boss Space Echo, Earthquaker Avalanche Run) are quiet as a mouse. It’s just the H90, which is causing all kinds of problems. I’ve not used the unit at all since purchasing it brand new, and was saving it for recording and it’s now probably out of warranty. I do suspect that it’s some sort of setting in the unit, as pressing the ‘Parameters’ button gets rid of it. I’m not much of a gear tweaker and was counting on the H90 Control to save some patches both for live use and recording. I’m posting this as a last resort to see if I can salvage anything from this unit. I just did the latest firmware update too. Any help would be greatly appreciated as I was really looking forward to getting creative. Thank you.
April 30, 2024 at 5:29 pm #181734
When you use the H90 do you have it connected to a computer via USB at the same time?
April 30, 2024 at 6:22 pm #181737
Thanks so much for the speedy reply… okay, so I think I’ve got things resolved. I reconfigured my setup for the four cable method in Dual Mode (rather than running exclusively in the loop). This has resolved the hum/noise issue (still don’t know why it was there in the first place, but I’ll take it!)… I need to work the levels of the unit (while getting used to it), but will do it tomorrow, as I don’t need the cops at my door! Thanks again for the prompt reply and I’ll report back tomorrow… so far so good! (What a great sounding unit!)….
November 7, 2025 at 6:30 am #193163
<span style=”font-size: inherit;”>I too am having noise floor issues with my H90.</span>
Ive tested the unit extensively finding no solutions, I can not use the H90 in its current state, reverting back to my h9 with the hopes a new firmware can fix the issue.
For testing I’m using guitar>H90>into 2 amps..
<span style=”font-size: inherit;”>Unit is isolated using supplied power adapter.</span>
signal chain is GUITAR>INPUT 1 (inst level)
guitar uses hum canceling Fralins.
OUT 1&2> RADIAL STAGE BUG>2 FENDER DELUXES (set at low volume) No other cable connections. All inserts set on inst level.
When unit Bypassed in relay mode = no added noise
DSP and AD mode Bypassed = Fidelity Noise and hum
When unit is engaged it always has noise present <span style=”font-size: inherit;”>even when Algorithms are off while Program is on, I get noise. As a comparison, the H9 is silent.</span>
Overall, this unit is not matching Eventide’s audio quality.
Is it possible my unit is from a bad batch?-
November 7, 2025 at 8:05 am #193164
Do you still hear this noise if you remove the Radial Stage Bug and connect the H90 outputs 1-2 directly to the amps?
Please email support@eventideaudio.com with a short video that demonstrates the noise and we can troubleshoot the issue further there.
November 7, 2025 at 5:47 pm #193174
Thank you for you reply…
Yes even without the Stage Bug there is a noticeable noise floor. I made a video and will send to support.
I can understand a unit with this much ARM based horsepower to have fidelity hiss, it’s more about the dry signal being effected. The dsp side of this unit is not the issue. It is amazing.overall, It seems like the buffer is adding gain to the clean signal with a considerable eq curve. Enough to change the reaction of my amps. I don’t think this is noticeable with line level instruments, just high impedance amp situations, the H9 are more transparent on input.
so I guess I’m just bringing this to your attention with the hopes that a attenuation setting or any buffer setting on input can be added to the globals in your next firmware? Perhaps a noise gate ? The wish would be to make the dry signal input more transparent and adjustable.
thank you!!
