H90 Manual only online?
Home Forums Products Stompboxes H90 Manual only online?
Viewing 5 reply threads
    • #166620
      drxcm
      Is there a plan to have a PDF of the H90 manual / algorithm guide?
      It’s very annoying to have to access it via a web browser!
    • #166621
      drxcm
      Ah- nevermind – I just saw there is a PDF icon in the HTML manual up the top that allows download … Jumping the gun – sorry!
    • #166628
      apalazzolo
      No one is ever more than two clicks away from the full manual. Do you see those three little lines in the top left of the control app? Click there. Do you then see where the drop down menu says “Open H90 Manual”? Click there and you’re all set.
    • #166629
      drxcm
      That still opens in a web browser though.
      No issue though as you can download a PDF from the HTML manual site – problem solved.
    • #166839
      kbarber
      Not sure whether this is the ideal way to request a manual update. If there’s a better way, just let me know 🙂
      small error at the end of section 6.2:
      Fig. 6.20 Presets A & B in Parallel on Path 1
      (should say “Path 2”)
      • #166852
        Thanks! This will be fixed in the next manual version.
    • #166855
      kbarber
      Super – thanks!!
