H90 mega crash #1
Home Forums Products Stompboxes H90 mega crash #1
    • #183519
      kopplog
      Happened to you the pedal crashes after beeping a high note? Happened to me… I’m seriously a bit afraid now (it should work in front of the audience u know)
      Try to recreate this bug.
      Meanwhile: steady Midi automation curve burst by DAW (Ableton, Win10) controlling the H90’s MIX of the PolyFelx-Algo ctrolled via MIDI through a iConnectivity MIDI2+… Happened after bout 7,8 mins.
      The editor stopped reacting, the pedal was to grt stripoed from the plug (and started again)
    • #183542
      Sorry for the issues you are having.
      Can you please email support@eventideaudio.com with some more information about the setup and MIDI data that caused this?
      You should also make sure your H90 is running the latest software version (1.8.6).
    • #183860
      Stratmaster
      Just wanna chime in and say that I have experienced the exact same thing – when connected to my computer and using the editor I have on a few occations recently have my H90 sending out a quick high pitched beep and then its scilent. If I then turn it off and restart it works again. Only happened when connected to my computer using the editor. I have a feeling it has happened when trying to manipulate programs with an external expression pedal connected, but that might be just a coincident.
      I was very nervous last weekend when I was doing a gig, but the H90 worked just fine, not connected to a computer.
