H90 MIDI Drop Out
Home › Forums › Products › Stompboxes › H90 MIDI Drop Out
    • #186752
      TroyReilly
        Midi will drop out-  At times, I can get midi to communicate and work perfectly, but then I shut everything off, come back and power it up, and it is completely unresponsive.  I’m running FW 1.9.7.181 on the H90.  My midi controller stays programmed and works with my quad cortex no problem when used with the QC- I have 2 separate midi controllers on the board- one for QC and one for the H90, each only communicating to their respective 1 device with no midi thru.
        I have configured all of these things to work, and when they work, it is ideal.  However, there is a ton of inconsistency in working.  I have tried different channels (1-16), enabling “receiving omni”, completely swapping cables, factory resetting & reconfiguring the H90, and confirming the MC6pro works with my QC.  There seems to be no rhyme or reason to when it decides to work or not work, and I have hours into this thing troubleshooting.  One thing that sticks out to me is that when the midi channel is “refreshed” or changed, this at times will get the controller to communicate.  Sometimes it takes the CC functions of the expression pedal, but does not take the PC messages from the regular stomps.  It is very strange, very inconsistent, and very frustrating.
        My setup is a Morningstar MC6 pro communicating directly to the H90 (no thru) and configured it to toggle mode (cc), engage tuner (cc), switch between 4 of my commonly used programs (PC’s), and use an expression pedal for various sweeping functions (cc).
        Not sure this matters but SN is XC-06905
      • #186785
          Sorry for the issues you are having. I see you have opened a support ticket, we can help you troubleshoot the issue further there,
