H90 MIDI over USB
Home Forums Products Stompboxes H90 MIDI over USB
Viewing 3 reply threads
    • #170236
      radiation360
        Should the H90 be able to receive MIDI over USB?  I’m using a Morningstar MC8, which can send via either standard 5-pin MIDI or USB.  If I send a PC message over the 5-pin it works, but over USB I get nothing.  Is this something that just isn’t implemented yet?  5-pin cables are extremely bulky and I’d much prefer to be able to use USB.
      • #170238
        joecozzi
          Hello radiation360,
          Yes, the H90 can receive MIDI messages via USB so long as the MIDI controller is acting as a USB Host device. The Morningstar MC8 is NOT a USB host device like the new MC6 Pro is. This may be the source of the problem.
        • #170243
          radiation360
            Well that’s a bummer (about the MC8), but thanks for the clear response – looks like I’ll have to replace my under-board hub.
          • #176899
            winihh
              Same here with Blackstar live logic controller. Does not work via USB.
              Is this the same problem?
              If yes… someone can recommend a controller for less money?
