H90 ModFilter
Home Forums Products Stompboxes H90 ModFilter
Viewing 4 reply threads
    • #173628
      jazznan
      How can I find or get the ModFilter for the H90? Seen in these videos: https://www.youtube.com/watch?v=tSz8nakVlx4&t=73s
      https://www.youtube.com/watch?v=vwuiabspwVU
      I can’t find it? Thanks
    • #173629
      It’s in there. Search through the Modulation Programs / Presets.
      https://cdn.eventideaudio.com/manuals/h90/1.5.2/content/algorithms/modulation.html#modfilter
    • #173646
      joecozzi
      To find the ModFilter algorithm specifically, press the Presets button. Set the Algorithm type to ModFilter. With Select you’ll be able to search through all the presets there are for that algorithm, but once you select any of them, you’ll be able to edit the parameters. You can put a Thru utility on the second algorithm or bypass it so you only hear ModFilter; it’s up to you. Follow the setting on the video you posted and you’ll be able to get the same results.
    • #173647
      joecozzi
    • #173655
      jazznan
      Great! Thanks everyone
