H90 Momentary Bypass: How to have it temporarily disable
Home Forums Products Stompboxes H90 Momentary Bypass: How to have it temporarily disable
    • #187041
      simosaba
        I recently got the H90 pedal and I am struggling to find the solution for a problem I encountered.
        I’m using a preset with a Reverse Reverb algorithm that I’d like to temporarily disable with a single press/hold of a footswitch for a specific part of the chord progression, in which that reverb isn’t needed. Is it possibile to do that?
        Because it seems to me that the H90 “Momentary Bypass” only lets me momentarily activate an algorithm and not momentarily bypass it. I’ve tried it with the algorithm both already active and already bypassed.
        Unfortunately, I haven’t found anything on the internet.
        If someone was able to kindly help me, I’d be extremely grateful.
        Thank you
      • #187049
        joecozzi
          True: It’s not possible to do it with one press; it is possible with two (bypass, then active). The momentary function only serves turn on the preset, not the other way around. One option is to use one of the Perform Mode Hotswitches mapped to the Wet Mix parameter of the Reverse algorithm. You can assign the Hotswitch (M) such that when it is engaged the value for Wet Mix is zero. When your foot is not on the Hotswitch (m) the Wet Mix is simply at its starting value. This will work how you want.
        • #187068
          simosaba
            Thank you so much for helping me! 🙂
