H90 – Mono Out – Mono In Insert and Mono Out – Stereo In Insert
Home Forums Products Stompboxes H90 – Mono Out – Mono In Insert and Mono Out – Stereo In Insert
    • #187442
      CRLCC
      My plan was to put two pedals as inserts into my H90. A simple overdrive, and the Chase Bliss Onward. What I love about the onward is the MISO functionality, which turns a mono signal into a stereo one. So my plan was the following setup.
      In1 – Guitar
      Out 1 – Overdrive
      In 2 – Overdrive Return
      Out 2 – Chase Bliss Onward
      In 3/4 – Chase Bliss Onward Return
      Out 3/4 – External Reverb
      However this is not possible is it?
    • #187445
      joecozzi
      The correct way to use pedals in the H90 inserts would be the following:
      Out 3 into external pedal, out that pedal back into the H90 on In 3. Same thing for the second insert using I/O 4. This way those inserts could be moved around the H90’s signal flow at will.
      Because the H90 can only have two mono or one stereo insert, there would be no way to send a mono signal and return a stereo signal for MISO functionality. You have to decide to either run the Onward in mono or stereo.
