H90 Output Using Balanced XLR Adapters
Home Forums Products Stompboxes H90 Output Using Balanced XLR Adapters
    • #187402
      Icewind
        Hi all.
        I am currently running a Line 6 Helix with the XLR outs set to line level with XLR cables running directly to our board in stereo. I don’t have any info on the board, but I have to assume the board is configured to accept the line level signal (I’ve been set up this way for years).
        If I want to connect using only the H90, can I simply set the outputs to line level and use two balanced cable adapters like these?
        https://a.co/d/65kxpHE
      • #187427
          Yes, that should work fine.
          • #187429
            Icewind
              Thanks very much!
