H90 Outputs 3/4 Sum to Mono (Dual Mode)
Home Forums Products Stompboxes H90 Outputs 3/4 Sum to Mono (Dual Mode)
    • #168821
      WrendorWC
      Hi all,
      I saw on TGP that outputs 1 and 2 will sum to mono if output 2 is disconnected.  Is this also true with output 4 in dual mode?  I use my pedalboard both 4CM with an amp and also (in stereo) direct.  I’m just wondering how sum to mono works in pre/post mode.
    • #168822
      joecozzi
      Hello WrendorWC,
      Yes, this is true. When running in Dual Mode, and you want a mono signal, you should use output three. The Algorithms automatically adjust for mono operation.
      • #168823
        WrendorWC
        Hello WrendorWC, Yes, this is true. When running in Dual Mode, and you want a mono signal, you should use output three. The Algorithms automatically adjust for mono operation.
        Thank you for the quick response!
