H90 pads for soloing
Home Forums Products Stompboxes H90 pads for soloing
Viewing 4 reply threads
    • #176324
      Danmusic1968
        I own two H90’s and wanted some ideas for ambient pads to play over top of with my guitar. I do not want the sound to get too muddy so that everything is lost of either too much guitar or too much effect. Maybe this involves using the looper.
        Thanks in advance.
      • #176333
          It depends on what kind of pads you are interested in. The newest PolySynth has a freeze effect that allows you to freeze/sustain the synth sound and then solo on top of it. Here’s a great example of that: https://www.youtube.com/watch?v=3XM2WSsQ9Qk
          You can do the same thing with Polyphony if you’d prefer for the pad to be less of a synth tone. The looper would also work well for this.
        • #176336
            The SIFT algorithms mentioned above are fantastic for pads.  I’d like to add that any reverb algorithm works nicely for pads with INF, FREEZE, or extremely long Decay options, and these can be faded in & out with an expression pedal / MIDI.
            You’ll only need one H90 for this; perhaps just 1/2 of one.  All of the mixing options are there to ensure the right balance between dry & effect, at both the Program & Preset levels.
          • #176343
            apalazzolo
              The UltraTap algorithm has a factory preset called UltraSwell that is a great starting point for pads.  You can control that with an expression pedal for smoother fade-out.  Or you can put reverb after it to smooth out the release.   Perhaps you can track that into the looper and then play over that by swapping in another preset to play along with the loop?  Good luck!
            • #176349
                Good point.  I didn’t want to confuse the issue in my reply, but many of the delay algorithms can mimic pads, with a healthy amount of SLUR / SLURM applied.  Sometimes, you don’t even need that [Ducked Delay with legato input].
                It never ceases to amaze me how any given algorithm can be re-purposed for another unintended or less-than-obvious use.
