H90 Parameter reset to default?
Home › Forums › Products › Stompboxes › H90 Parameter reset to default?
    • #184781
      jameson
        I am unable to find a quick method in the app and on the device itself for reseting a given parameter to it’s original preset setting.    Is there a way to do this?  Pressing and holding the a quick knob doesn’t do it, as that opens the parameter mapping menu.
      • #184782
        jameson
          I guess that brings up another question. When saving a preset, I assume that it saves your parameter settings.  So is the only way to reset a parameter is to reset them all be reloading the whole preset or the program? That seems a bit much.
        • #184790
            There is currently no way to reset the parameters to default settings, but this is something we are considering. Yes, saving a preset will save all of the parameters, and reloading a preset will give you the preset’s saved values.
            Let me know if you have any other questions.
