I have a MIDI specific question (H90):
I know how to get into perform mode via MIDI. But can I also jump directly to the second page of the perform mode via MIDI?
Activating PERFORM mode directly into the second page is not possible. However, it is possible to map globally PERFORM mode functions directly to MIDI CC#s. If you look at the global performance mapping chart, you’ll notice there are options for PERFORM 1, PERFORM 2…PERFORM 6. You are able to directly access those functions. In your case, “second page” parameters would be PERFORM 4 through 6.For clear instructions on how to do this, watch this (21:20): https://youtu.be/5y14LwN9oAk?t=1170&si=hJ9Z8dCXIer0LERC
Thanks, Joe, for your suggestion!
However, it has the disadvantage that I have to sacrifice switches on my midi switcher for the hot switch functions. I wanted to use the (Hot Switch) switches directly on the H90.
Anyway, I’ll just put the hot switches on page one – that will be an easy workaround.
