H90 Phase Flip feature?
Home Forums Products Stompboxes H90 Phase Flip feature?
Viewing 3 reply threads
    • #169491
      streamcore8
      Hello everyone!
      Didn’t find an info in the manual and faced the searchbar issue there, so hope the question is not too common.
      Planning to get H90 in order to replace a parallel mixer pedal with couple of modulation effect pedals I used to connect in parallel.
      Each of parallel lines also has a drive/fuzz in them, and I want to use them with H90 as Insert 1 and Insert 2.
      Wanted to ask, does H90 have a phase flip feature for preventing possible phase cancellations/volume drops, or maybe it maintained in other way somehow?
      Thank you in advance.
    • #169492
      joecozzi
      Hello streamcore8,
      Thank you for your question. Yes, the H90’s inserts have a polarity inverter switch. We talk about it in section 6.2.1 of the manual where we explain it can be used to calculate latencies of external digital pedals: https://cdn.eventideaudio.com/manuals/h90/1.1.2/content/edit-modes/routing.html#insert-routing
      • #169509
        streamcore8
        Was so distracted by reading about routing options and missed this part, now I’m excited even more, huh
        Very much appreciated, joecozzi!
    • #169515
      I could see some potential uses for Phase Invert on the main signal lines, too.  ‘Course, that would also have the potential for unintended consequences.
      It’s probably a safer bet to simply jump the Inserts with short patch cables.
    • #183693
      Rezzy777
      If I may ask, why isn’t this phase switch available with Dual Mode (can’t find it anyway)?
      I am new to this so my apologies if this is such a n00b question 😉
