Home › Forums › Products › Stompboxes › H90 Playlist/Program issue
- This topic has 3 replies, 2 voices, and was last updated 2 years, 2 months ago by
Eventide Staff.
January 16, 2024 at 3:50 pm #177430
Am I correct in understanding that any programs Ive made in insert mode cant be transferred to Dual mode? I have a bunch of programs Ive made with a wind synth (stereo ins 1 +2) and want to use them with my horn (mono in 3). Do I have to recreate these programs after switching to Dual mode? If this is true is there a work around?
Greg
January 16, 2024 at 4:02 pm #177431
Yes this is correct and no there is no workaround. Programs created in Insert Mode cannot be used in Dual Mode.
Can you provide more information about the setup? Will you be using the wind synth and the horn at the same time in Dual Mode?
If you will not be using the wind synth and the horn synth simultaneously, you can always connect the horn to input 1 and continue using the Programs you’ve made already.
If you are reconfiguring these Program to use 2 sources in Dual Mode, then I’d imagine you will need to edit the Programs anyways since you will now have 2 sources and 2 signal paths to choose when routing your effects.
January 16, 2024 at 4:50 pm #177432
Ah! No I wont play them at the same time. So you’re saying put the mono horn into input one and stereo wind synth into 3/4?
January 16, 2024 at 5:25 pm #177433
You’re welcome. I should have worded my question better. It’d be pretty impressive if you were playing both at once!
What I meant was, is this for a live setup where you will need access to both instruments and do not want to disconnect anything? Or is this for at home/recording where you can reconnect some gear when needed.
If this is for at home/recording, I would suggest plugging in your wind synth to 1-2 when you want to use that, and then disconnecting it and plugging in your horn to 1 when you want to use that. This way, you just have 1 set of Programs.
If this is for live, then you may want to use dual mode, but this will require connecting outputs 1-2 and 3-4 to a mixer or 2 monitor sources. Also, you will need to configure your Programs so sometimes you have Presets on Path 1 for the wind synth, and other times you have Presets on Path 2 for the horn. You may also need to mute the horn path when you aren’t playing it to avoid feedback.
Either path can be mono in > mono out, mono in > stereo out, or stereo in > stereo out depending on what input/output connections you hook up.
