H90 Power draw & routing
Home Forums Products Stompboxes H90 Power draw & routing
Viewing 71 reply threads
    • #166740
      MrClean
        Hi all, just ordered y H90, thanks again Eventide for the continued evolution of the product line ! Couple of questions: what’s the power draw in milliamps for power brick integration ? Are the routing combinations (in/out/stereo/dual mono) configurable on a per preset basis ?
        thanks
      • #166743
        MrClean
          Should add – I mean the I/O config routing (not the internal signal path)
        • #166749
          joecozzi
            What’s the power draw in milliamps for power brick integration?
            Although we provide a 12V 1 amp power adapter, the H90 can be powered with 600mA. Testing with our own PowerMax/Mini products we can safely run it at 12V 500mA because of the excellent efficiency of those power supplies. 9V works as well, but it’s a hungry 800mA.
            Are the routing combinations (in/out/stereo/dual mono) configurable on a per preset basis ? thanks
            The H90 has two global routing modes – Dual mode and Insert Mode. When you designate one, the program routing (series-parallel, insert positions [insert mode only]) can change on a program basis. Keep in mind, however, that Programs designed in Insert Mode do not work in Dual mode and Vice versa.
            • #166763
              jm345
                I have a power brick (Voodoo Power 3 Plus). Would combining two 9V 500mA outputs with a current adapter to get 9V 1000mA work OK?
              • #168149
                ear5555
                  If you’re using a pedal Power 3 Plus, simply use one of the 12V 1A outputs on the far left side of the power supply. This is more than enough juice and the optimal voltage.
                • #169547
                  willcrook69
                    does the power mini come with a cable that will go straight into the h90? if so I’m going to buy one straight away!
                  • #169564
                    joecozzi
                      Yes.
                  • #166765
                    joecozzi
                      Yes. Voodoo makes the Current Doubler adapter.
                    • #166767
                      jm345
                        Thank you!
                      • #166781
                        lelevox
                          And what about ciocks DC7?
                          it provides max 12v 500ma
                          is a double cable needed in this case too?
                          thanks
                          • #166783
                              A single 12V 500mA outlet from a DC7 will power the H90.
                            • #166800
                              coirbidh_99
                                But *not* the 12V 400mA outlet from the original PowerFactor? That’s what I’m using now, and it *seems* to be working properly, but I’m starting to get a little paranoid about it.
                            • #166803
                              MrClean
                                Hi all, and Eventide gurus ! The complexities of electricity !
                                Just to confirm (as im a bit nervous about hitting the unit with 18v)  – 2@ 9 volt, 400ma outputs combined with the Voodoo Lab current doubler https://voodoolab.com/product/current-doubler-adapter/ will work with the H90 and not damage the unit ?
                                I am using the following https://www.sweetwater.com/store/detail/PedalPwrDig–voodoo-lab-pedal-power-digital-4-output-isolated-guitar-pedal-power-supply
                                Utilising the two 9 volt 400ma outputs as described above. Thanks !
                              • #166804
                                joecozzi
                                  We do not recommend under powering the unit with only 400mA.
                                • #166805
                                  joecozzi
                                    Just to confirm (as im a bit nervous about hitting the unit with 18v) – 2@ 9 volt, 400ma outputs combined with the Voodoo Lab current doubler https://voodoolab.com/product/current-doubler-adapter/ will work with the H90 and not damage the unit ? I am using the following https://www.sweetwater.com/store/detail/PedalPwrDig–voodoo-lab-pedal-power-digital-4-output-isolated-guitar-pedal-power-supply Utilising the two 9 volt 400ma outputs as described above. Thanks !
                                    You will be alright.
                                  • #166806
                                    joecozzi
                                      By the way, this cable s doubles the current not the voltage, so you’re not hitting it with 18v.
                                    • #166807
                                      MrClean
                                        Thankyou joecozzi  – fed ex mentioned my unit is somewhere south of Hawaii over the pacific. Hopefully it will get to Australia (without a stop over at the Marshall Islands) 😀
                                      • #166819
                                        ed536m
                                          I have a cioks dc5 if I use the CIOKS 4022 Type 4 Stack Flex Power in the outs that have 300ma each would that be enough to power the H90? Two 12v at 400 ma each.
                                          thanks
                                        • #166824
                                          joecozzi
                                            I have a cioks dc5 if I use the CIOKS 4022 Type 4 Stack Flex Power in the outs that have 300ma each would that be enough to power the H90? Two 12v at 400 ma each. thanks
                                            No. The stack flex cable is used to add the voltages of each outlet. The H90 cannot accept 18V or 24V.
                                          • #166826
                                            ed536m
                                              Ok thanks. Is it the cioks 8800 that doubles the ma? So if I used two 12v 300ma outlets with cioks 8800 will that then provide it 12v 600ma and would that be safe?
                                              thanks again
                                            • #166827
                                              joecozzi
                                                Yes and yes.
                                              • #166989
                                                canadabikedude
                                                  Hey there. Looking forward to receiving my unit soon. I am currently running power to m H9 with current doubler cable from my Voodoo Labs pedal power two from the two “Line6” outlets. Will this work for the H90 as well?
                                                • #166990
                                                  joecozzi
                                                    If the dip switch is ON for 12V functionality and you use a current doubling cable, you’ll achieve the minimum amount of power to turn the unit on. So, the answer to will it work is yes. However, at boot up, the H90 spikes to about 550mA. I am not familiar with that power supplies ability to handle that since this method would only top out at 500mA. I would search elsewhere.
                                                  • #167196
                                                    zambiland
                                                      I just confirmed with True Tone that their CS7 will power the H90. Even though the highest current output is listed as 500ma, the total current load can be up to 1900ma which is automatically distributed as needed, as long as the total draw doesn’t exceed that total current number. Given that my other pedals draw about 200ma, I have a fair amount of headroom.
                                                      • #167197
                                                        peaceonu
                                                          Hi
                                                          I have a JUMA pedal power from stymon and it has 12V 500mA output option. Do I still have to use current doubling cable for the enough amount of current?
                                                        • #167198
                                                          peaceonu
                                                            I’ve just found that JUMA 12V provides 350mA not 500mA, so I would need use current doubling cable.
                                                          • #167579
                                                            corbeano
                                                              I tried this today, It powered up, but a very loud hum.
                                                              Does anyone have any idea what the hum is from?
                                                              Works great with no hum with the wall wart it came with.
                                                            • #167581
                                                              joecozzi
        If you’re using one 9V 500mA outlet, my guess is that you’re under powering the H90. You need a current doubler cable and combine the 500mA outlets.
                                                              • #167584
        zambiland
        I have no idea where the hum is coming from (maybe a grounding issue with another pedal?). I used my CS7 to power an H90 with 3 other pedals and it worked perfectly. Make sure you are using the polarity reversal adapter.
                                                              • #167592
        corbeano
        i have the CL6 cable plus should not be a ground issue if the wall wart works just fine.
        i will grab a current doubler and see what happens  thanks
        • #167594
        willcrook
        has anyone else tried this and can report? really don’t want to have to buy a new pedal power supply to power the h90 🙂
        • #167599
        joecozzi
        Specs wise, this should work as long as you switch the outlet to 12V. According to the manual, using a current doubler cable should give you 500mA (12V 250+250). I know the H90 has a startup spike of around 565mA. I don’t know whether the Pedal Power 2 Plus has the capability of reinforcing current where it’s needed for this spike like other manufacturers. May want to ask their support. This is the reason Eventide recommends 12V 600mA.
        • #167608
        b_e_a_d_g_c
        Noob question for the people powering the H90 with power supplies – Are you all using reverse polarity adapters ? I’m under the impression that the H90 is center positive, and most power supplies are center negative.
        • #167609
        joecozzi
        That is correct. If you are using a power supply other than Eventide or Coiks, a reverse polarity adapter with a 2.5mm end going into the H90 is required.
        • #167642
        b_e_a_d_g_c
        Much appreciated, Joe
        • #167751
        harperengineering
        <p style=”text-align: left;”>Hey Joe, I rebuilding my board to accommodate the H90 and have a DC7. I intend to run this at 12V which should supply 500mA, which you stared should be adequate. I also see you mentioned if you’re using a Cioks you don’t need a polarity reversing power cable? What’s the reasoning there? I have one of their red tipped cables which I thought was for that purpose. Thanks!</p>
        • #167753
        joecozzi
        I intend to run this at 12V which should supply 500mA, which you shared should be adequate.
        Correct, this was confirmed by Cioks.
        The green Cioks cable, the Flex type 4, already incorporates a center-positive connector that is 2.5mm.
        The red cable, or the Flex type 2 cable, is also center-positive but it is 2.1 mm connector not suitable for the any Eventide pedal.
        • #168063
        kevo888
        I can confirm my Cioks DC7 at 12v with included green cable works great with H90.
        • #188008
        dkijc
        Hi, I have Cioks DC7. I set it to 12V 500mA. When I power the H90 I hear clicks :(. That happened when I tried to power my HX stomp. The sound went away as soon as i got a doubler cable for it.
        • #188016
        Sorry, I’m not sure what this issue is. Are you sure the setting is correct? 12V at 500mA should work fine.
        Please send a video of the issue to support@eventideaudio.com.
        • #168066
        b_e_a_d_g_c
        Kevo888 are you using 2 , 12v outlets to power it , or just 1 @500ma ?
        • #168068
        kevo888
        Just one at 12v.
        • #168133
        philh0954
        I’m still pretty confused with this whole power draw thing. I understand I will probably need a current doubler cable for my Stryman Zuma  https://www.sweetwater.com/store/detail/PPAP–voodoo-lab-current-doubler-adapter-4-inch-str-str-y-doubler
        And I need a reverse polarity cable to hook into the H90. Here’s the confusing part, at least for me. Sweetwater sent me this link for the reverse polarity cable.  https://www.sweetwater.com/store/detail/DCRR2.5RP18–vertex-effects-2.1mm-2.5mm-angle-angle-reverse-polarity-dc-cable-18-inch
        And Stryman sent me this link for the cable I would need.   https://www.strymon.net/product/polarity-reversal-cable-2-5mm/
        My rep from Sweetwater said that cable from Stryman wouldn’t work and the rep from Stryman said that people with H90’s are using it. Seems like 2 entirely different cables. Can anyone point me to exactly what I need to hook the H90 up to my Stryman Zuma? Thanks!
        • #168134
        philh0954
        Sorry I forgot to put the correct links in to my last message. I guess there’s no way to edit comments after you make them.
        • #168135
        joecozzi
        Hi philh0954,
        Strymon doesn’t sell a current doubler cable, so I would go with the Voodoo Lab/Vertex combination of products. Together they will allow you to power the H90 from your Zuma. The problem with the Strymon adapter is that it’s female on one side, so it would only work for a pedal that only needs the power from ONE outlet and in conjunction with one of their barrel cables. That’s not the case with the H90. Hope that clarifies things for you.
        • #168137
        philh0954
        Thanks for the clarification. I’m still thrown of a little bit from the email Stryman sent me. Here the text of it:
        “We have never used the cable that you’ve just linked, however, we’ve had customers use our polarity reversal cable with a current doubler for Eventide products for years with no issues whatsoever.
        The current and polarity adapters that we sell still require the standard DC power cable that Zuma/Ojai comes with in order to connect it all. It appears that the Sweetwater rep may not understand this.
        I hope this clears it up for you!”
        What you are saying I believe is that all I need to power the H90 with my Zuma is the current doubler cable and the Vertex reverse polarity cable that Sweetwater linked to. I will not need the cable that comes with the Stryman, right?
        • #168138
        joecozzi
        I’m still thrown of a little bit from the email Stryman sent me. Here the text of it: “We have never used the cable that you’ve just linked, however, we’ve had customers use our polarity reversal cable with a current doubler for Eventide products for years with no issues whatsoever.The current and polarity adapters that we sell still require the standard DC power cable that Zuma/Ojai comes with in order to connect it all.
        I do not see a current doubler adapter on their website, so we’re both confused.
        Correct.
        • #168139
        philh0954
        They had told me they don’t sell the current doubler.
        Here’s another email I just got from them:
        Victoria Godfrey (Strymon)
        Jan 2, 2023, 15:53 AKST
        Hi Phil,
        Attached is a screenshot from Eventide’s website stating that the H90 is positive polarity.
        We do not sell current doublers, as previously mentioned. You could use this current doubler:
        Which would connect to the DC power cables that come with Zuma, which then would connect to our red-tipped polarity reversal cable:
        Which would then connect into the H90.
        I hope this clears it up for you.
        • #168140
        joecozzi
        What they’re forgetting to tell you is that with Strymon’s adapter you would have to use one of their barrel cables in between. Two adapters with female connectors alone can’t be joined.
        • #168141
        philh0954
        So you’re saying that I could do it with their reverse polarity cable but would need to use their barrel cables as well. Basically with their way I’d need 3 cables attached together and Sweetwaters way would only be 2 cables, right?
        • #168142
        joecozzi
        Correct.
        • #168627
        hunttownsend
        I have two available ports on a “Pedal Power Digital” supply. Each port is 9V 400ma. If I use the Voodoo Labs current doubler adapter, will the H90 receive sufficient and “healthy” power?
        • #168628
        joecozzi
        Yes
        • #168634
        hunttownsend
        One more annoying question (first Nasa pedal of this type I have ever had). I see normal power cable connectors are too small to fit the male power connection on the H90. I have a current-doubler cable ready to, so what pedal power cable will fit properly on the H90’s power connector coming from the end of the current doubler cable?
        • #168635
        joecozzi
        2.5mm center positive connector. Like this one: https://voodoolab.com/product-category/cables/reverse2-5/
        • #168652
        zambiland
        Please make sure that you are delivering the correct polarity. I use a TrueTone power supply and I had to get an adapter that went from center negative to center positive.
        • #169530
        mferrar
        Sounds like i could use a single 12v output from a Strymon Ohai r30?
        • #169534
        joecozzi
        No, That’s not enough power as the 12V outlet of the Ojai R30 only puts out 375mA. You could use either two 9V outlets with a current doubling cable and a polarity converter cable with a 2.5mm barrel on the H90 side, or you can use two 12V outlets with the same cables.
        • #169561
        mferrar
        Oh, actually the current drops to somewhere around 360ma or so when selecting 12v on the ohai so I guess I’ll need a current doubler
        • #170743
        wcranston
        I got my H90 and the inclosed power supply is 12v 1A. I have the the Eventide PowerFactor v1.2 that will only do 12v 400mA. How can I use this power supply or do I need to do something else.
        • #170745
        joecozzi
        If it’s the PowerFactor 2 then you’ll need to combine outputs 7 & 8 using a current doubler cable (8800 Parallel Flex) into a green Flex cable to power the H90 properly.
        • #170749
        wcranston
        It doesn’t say PowerFactor 2, just PowerFactor but it has the following and it appears that that will work. So 12V 800mA is good?
        Outlet 5-6: 9 or 12 V DC / 400mA
        Outlet 7-8: 9 or 12 V DC / 400mA
        Outlet 9-10: 9 or 12 V DC / 400mA
        I don’t know if you can answer this and it’s not related to the H90 but is there a way to combine two 9V outlets to get 18V plus double the amps?
        • #170751
        joecozzi
        Yes, you’ll have to combine two of the 12V 400ma outlets with a parallel current doubling cable.
        Yes. For this you need a Voltage Doubling cable. 2200 Series Adapter cable. By using two isolated outlets the Series adapter Flex gives you the sum of voltages of the two outlets used. This adapter Flex cable should be used in combination with any of Eventide/CIOKS standard Flex cables if you want to power an 18V, 24V, or even a 40V pedal.
        DO NOT USE THIS FOR THE H90!
        • #171653
        david_grubby
        VL Pedal Power 3 Plus user here. Is there not simply a single cable that will connect the PP3P to the H90?
        Would this one work, attached to the 12v 500mA outlet?.. https://voodoolab.com/product-category/cables/reverse2-5/
        • #171656
        udi9
        VL Pedal Power 3 Plus user here. Is there not simply a single cable that will connect the PP3P to the H90? Would this one work, attached to the 12v 500mA outlet?.. https://voodoolab.com/product-category/cables/reverse2-5/
        I’m also using the Pedal Power 3 and asked Voodoolab about it. They suggested to use one of the 12V X-Link (1A) outputs with a reverse polarity 2.1mm/2.5mm cable. Works like a charm!
        This is the cable you need:
        • #171659
        david_grubby
        I did wonder if I could use one of these outputs, but was paranoid I’d screw up my lovely new pedal. That’s perfect as I have that cable already. Thanks!
        • #172849
        hickrj
        Hello Eventide Team
        I have a strymon Ojay R30. In this unit, it have 2  switchable outlets (9 V DC @ 500 mA, 12 V DC @ 375 mA & 18 V DC @ 250 mA)
        Could i use voodoo PPL6-R and Current Doubler Adapter PPAP?
        How can i power up my H90 with it?
        Greetings from Brazil!
        • #173071
        joecozzi
        Yes, this the correct configuration of cables. Sorry we didn’t see this message sooner.
        • #173068
        Thingsthinker
        Hi team!
        Recently got my h90 and loving it but I would like to add the pedal to my current daisy-chain powerunit with plenty of juice at 9v, barrel plugs of 2.1 mm and center negative. What adapter/do you suggest I buy? I’m located in Europe/Holland. Would one of these work? Otherwise – what do you suggest?
        https://www.bax-shop.co.uk/guitar-effects-power-cables/strymon-polarity-reverse-cable-2-5-mm-2-1-mm-straight-15-cm?q=eventide%20polarity
        https://www.bax-shop.co.uk/guitar-effects-power-supply/truetone-cl6-l6-converter#information
        • #173072
        joecozzi
        These adapters will do the job provided the power outlet puts out 800mA @ 9V or 600mA @ 12V. Otherwise, you will need to combine more than one outlet with a current doubler cable.
        • #173187
        d.arayamanz
        Hi all,
        I confirm that powering up the H90 with Voodoo Lab Pedal power 2+ (outputs 5 & 6 w/ dipswitch in the up position) works just right so far.
        I built myself a custom current doubler + polarity inverter connector, but you can use the adapters sold by Voodoo Lab.
        Hope it helps!
        • #176114
        jazznan
        Can I use the Pigtronix power supply to power the H90 by combing two 12v 300ma slots?
        • #176115
        joecozzi
        Yes, as long as you use a current doubling cable, not a voltage doubler. Keep in mind the input to the H90 is reverse polarity (center-positive) and 2.5 mm.
        • #176116
        jazznan
        Thanks. I’m assuming a current doubling cable is easy to find?
        What are the two best power bricks you recommend?
        Does the smaller version of the Eventide Cioks power the H90?
        • #176118
        zambiland
        I love the True Tone One Spot CS12. It handles an H90 and a bunch of other boxes with ease. It also automatically assigns current where needed, so no current doubling cables needed. It can provide a total of 3000ma of current, which should be enough for a lot of pedals.
        • #176122
        jazznan
        Thanks! Could explain to me how Mmmm which port you would connect the H90 to? Thanks (I’m a total newbie)
        • #176223
        Kiniu
        I have a power supply that has 10 isolated outputs, but only one is 12v 300ma… according to what I read here, it’s not enough for powering the h90… therefore I need the double current cable…
        but here is my doubt:
        The power supply has 3 outputs of 9v 300mA and only one of 9v 500 mA.
        To reach the 9v 800ma required by the h90 I will have to combine the output of 500ma + one of 300ma… Would there be any problem with combining these different outputs??
        Thanks.
        The h90 is amazing!
        • #176224
        joecozzi
        No problem at all.
        • #176225
        Kiniu
        Perfect! Thanks for your reply Joe….
        Also want to know if its any difference in performance or sound between using 12v vs 9v ??
        • #176226
        joecozzi
        There is no difference in performance or sound.
        • #178326
        Modular1
        Can I safely run 4x H90s on an Eventide Powermax by Cioks power supply?
        Would there be any issues with the startup current mentioned? In theory could you safely run 7?
        • #178345
        joecozzi
        4 H90’s at 12V, Yes. 4 at 12V and two coupled 9V outlets for a fifth unit, yes.
        • #178343
        zambiland
        Can I safely run 4x H90s on an Eventide Powermax by Cioks power supply? Would there be any issues with the startup current mentioned? In theory could you safely run 7?
        Must be quite a rig with 4 H90s!
        I don’t know if the Eventide Powermax will provide enough current. It appears that at 12 volts, it provides 500ma for each output, instead of the suggested 600ma. I use the True Tone One Spot CS12 and it can handle up to 3000ma which is automatically distributed across all available outputs and has 4 12v outputs.
        I have one and it’s been flawless.
        The Powermax may work if you start up each H90 separately, but that’s a wild guess.
        • #178346
        Modular1
        Well I’m just spitballing. It’s not a massive rig at all. It’s really just a massively pimped Analog Rytm and some synths. Im definitely going to have 3 so it sounds like it should be worry free with the powermax. I’ll add the true tone to my reading list though.
        • #178348
        zambiland
        Well, Joe is the man, so either would work.
        • #181126
        Anthony
        is there any sonic or physical benefit to running 12v 1a vs 12v 500ma?
        • #181134
        No. Note that we only officially recommend using an Eventide or Cioks equivalent power supply when using 12v 500ma as we have tested those specific power supplies.
        • #181413
        indigojc
        Hello there. At the moment I’m powering up underneath my pedalboard with the original power supply connected directly to my Furmann conditioner. All other pedals are connected to two different power bricks. I’m all nervous about it too, like many here, of using the bricks for my H90. So, that being said, One of my bricks is the “Palmer PWT 12 MK2” (love the unit) I did not try it with it yet. This unit has a bunch of 9v 300 mA and four 500mA in which you can choose 9,12,18 or 24 v. Would be safe for the H90 if using two of the 500mA at 9V to power it up? or better another combination. That way I could use the bricks and put the original power supply out of the board. Thxs in advance.
        • #184000
        Skman
        Are there benefits to running the H90 using a 12v supply over a 9v? Headroom, processing speeds, or any other useful or operational benefits?
        • #184001
        There will be no difference in how the pedal operates.  They are just different options to power the pedal depending on what power supply you have etc.
        • #190427
        jamos
        Hi;
        I’m gathering backup supplies for my system and I am wondering about the H90’s voltage regulation. Can I run it from a 15v 1A supply? This would let me share a single backup (not simultaneously) with my Radial Key Largo.
        TIA
        • #190428
        joecozzi
        No. 12V or 9V only.
        • #190525
        pfrf
        I have an H90. I have two spots left on my Fender Engine Room power supply- one is 9v500mA, the other is switchable so I can also get 12v375mA. Can I combine 9v500mA with 12v375mA, or would it be better to combine 9v500mA with 9v500mA? Does the pedal sound better at 12v than it does at 9v?
        • #190534
        joecozzi
        No, you should not combine two different voltages together. Yes, combining two 9v 500mA outlets is the best option.
        No, it makes no difference sonically with a digital pedal.
        • #190544
        pfrf
        Thanks for the quick response, that’s good information.
        • #190617
        pfrf
        Well I’m going crazy here. I cannot find a combination of currently available cables or adapters to power the H90. I have a Fender Engine Room. I have available 2 9v500mA outputs (2.1mm). So I need a current doubler cable. Then I need to convert that to a 2.5mm plug. And also switch the polarity to center positive. So I need three cables with the correct female/male plugs. In what order?
        There is a Gator cable that does two things- doubles the current and ends in a 2.5mm male plug, but it’s still center negative.
        why why why why why why why why why
        • #190619
        pfrf
        Thank you!
        • #190685
        Bradbracket
        I have a Voodoo Lab Power Pedal Plus 3, I’ve seen that they say you can connect one of the 12v 1A outputs on the left side of the power supply to the H90, but do I need a polarity adapter?
        • #192088
        jononotbono
        Sorry If I have misread anything here but I have a Voodoo Labs Pedal Power Plus 3 and is it possible to use it to power the H90? Would love to stop using the adapter that comes with the H90.
        I’m using all 12 DC power outputs already but I’m curious about the 12V 1A two outputs on the far left of the Voodoo Labs?
        Please someone make my Friday night 😂
        • #192091
        It looks like the comment directly above this post is the same question, but I’m not familiar with this power supply and the manual doesn’t provide much info.
        I’d suggest contacting Voodoo labs and see if they recommend using one of those ports to power a single device. The manual states these ports are for powering expanders, but they may work fine.
        • #192098
        jononotbono
        haha! Sorry I totally didn’t even see that. Yes, same question!
        • #192100
        jononotbono
        Just been doing a big of digging and those 12v 1A power outputs are not for powering pedals. They are for powering Voodoolabs Expansion units and then using an expansion units, you can power the H90. Guess I’m buying an expansion unit then 😂
        • #195213
        mathewjoseph
        I’m using a Cioks Dc 4 powered by a power bank via USB C. Works great for my pedals. Recently acquired an H90… I saw an earlier [post about powering it with a DC7. As I understand the DC4 should work the same way. So 12V at 500 ma through the Green Flex cable from the DC4 powered via power bank should also work…yes?
        • #195215
        Yes, that will work fine. Congrats on the new H90!
        • #195217
        h90rus
        Can confirm cioks 4 expander with 12v output, powered by an appropriate usb C using their green flex cable, no doubler, will power the h90 fine.
        • #196107
        crussell
        I have a Voodoo Labs Pedal Power 4×4. Looking at the ports on the 4×4, the first two sets of ports are 9v next to a 12v with both noted at 400 mA. These are individual taps/physical ports, not using a dipswitch. Visually, it’s one 400mA section with both a 9v and 12v port, next to a second 400mA section with a 9v and 12v plug in. Hope that makes sense. Currently I have my H90 plugged into the two 9v 400mA ports using the current doubler cable and it seems to work fine. However, I’m reading that I should consider using the two 12v 400 mA ports instead because it would be a more efficient use of the power supply.  Is that true and is that safe?  I don’t want to burn up the H90. Can I use two 12v 400ma ports with the doubler cable to power the H90 with this power supply?
        • #196108
        joecozzi
        Either one will work for the H90. The pedal will only draw what it needs. Your current configuration is fine.
        • #196109
        crussell
        Thanks for the quick response. Is there any minor advantage or disadvantage to using the 12v ports over the 9v ports? Is it easier on the 4×4 power supply?
        • #196110
        joecozzi
        As far as the H90 is concerned there really isn’t an advantage. As far as the Voodoo Lab performance, I recommend reaching out to the Voodoo Lab folks for their take.
