H90 power supply connector size/technical details?
Home Forums Products Stompboxes H90 power supply connector size/technical details?
    • #177696
      apalazzolo
        What size connector does Eventide use for the H90 power supply?
        I’m using the H90 factory power supply but would like to add an extension to the cord.
        I bought an extension cord with the standard 2.1mm x 5.5mm connectors but the male end  cannot be inserted into the female connector on the back of the H90  (my guess is that the center pin is too large to fit into the extension cord).
        I tested various other power supply cords and none fit into the H90 except for my H9 factory power supply cord.
        Does anyone know the connector size I need when I buy another extension cord?
        Thanks.
      • #177701
        kreator1972
          Center Positive (+), 5.5/2.5 mm jack
          12 VDC 600 mA or 9 VDC 800 mA
        • #177716
          apalazzolo
            Ahhh.  Got it!  Thank you.
