Home › Forums › Products › Stompboxes › H90 Public Beta 1.9.4 bugs
- This topic has 8 replies, 5 voices, and was last updated 11 months, 3 weeks ago by
Eventide Staff.
October 19, 2024 at 4:47 am #185513
It’s still in beta and I expect these bugs are being sorted out but bluetooth connection to Mac OS no longer works with 1.9.4 . On the H90 only a single blue light comes on and Mac OS cannot find the device. Same problem on iOS. H90 Control is working fine on Mac OS but not in iOS . The new looper foot switch control and display is a big improvement but the stop / start command no longer works ; it stops the loop but does not restart. Just my two cents worth 🤨
October 19, 2024 at 2:52 pm #185521
I’m also having problems I wish I would have known I use this quite a bit so we are dead in the water till the update the control app. I think it must have something to do with the current IOS 18 that just came out. I haven’t tried it with my MacBook but Ill let you know what I find out
I have a m4 iPad Pro 13 that will no longer connect this is my main gigging unit so this is a bummer but they are usually pretty good with this stuff so I am crossing my fingers
October 19, 2024 at 3:54 pm #185528
Got it sorted on my MacBook Thank you Eventide for being quick on the responses! I am looking forward to trying the control beta for the iPad!
October 21, 2024 at 8:30 am #185544
Hi Patric,
For your Bluetooth issue, please refer to the MacOS pairing tips section of the manual. It sounds like you need to follow the instructions to forget the device on your computer and H90 and reinitialize the Bluetooth connection: https://cdn.eventideaudio.com/manuals/h90/1.9.4/content/system-menu/bluetooth.html#macos-connection
Can you please be more specific about the Looper issue you described? There is no Stop/Start command. There are separate Stop and Play controls. Play can be use to restart the loop depending on the setting of the Playmode parameter. Please refer to the Looper documentation to confirm if the Looper is working as described: https://cdn.eventideaudio.com/manuals/h90/1.9.4/content/algorithms/looper.html
October 24, 2024 at 4:48 am #185720
After I installed the beta I deleted the H90 from my list of bluetooth device on Mac OS and also configured the H90 to ‘forget’ the device. After installing the beta only one Bluetooth light was showing , where there had previously been two , and my Mac was not able to find the H90 in the Bluetooth settings on Mac OS. Prior to installing the beta the bluetooth connection had worked flawlessly.
As regards the stop start command I am referring to the stop start midi command sent by my Maschine MK3 controller. Apologies for flagging this as a bug I had a faulty midi lead going into the H90 from my hardware output on the MK3. The H90 looper with the new hardware switch controls works really well with Maschine. 🙂
October 24, 2024 at 5:41 am #185722
Hi – re: least post – I’ve been able to connect via Bluetooth ! Problem caused by being connected to another device 😬
October 24, 2024 at 8:03 am #185724
Hi Patric,
Glad to hear you were able to resolve the issues and thanks for reporting back!
November 1, 2024 at 5:47 pm #185991
Hi I just installed v1.9.4 and o cannot connect to the pedal at all. This is from my Mac running is 18. App just crashes after retrieving the presets.
switched to my iPad to try to connect and it also crashes. I have not updated my software on the iPad hoping it would connect.
November 4, 2024 at 9:23 am #186001
The public beta software v1.9.4 requires that you use the H90 Control public beta v1.8.6. Please install that version of H90 Control and let me know if that resolves the issue.
