H90 quad / immersive
Home Forums Products Stompboxes H90 quad / immersive
Viewing 0 reply threads
    • #186316
      ekkoarkitekt
        Hi. Im sorry if this has been covered somewhere in the forum….if so – i havent been able to find it.
        Im in the proces of building out a quad setup with my Buchla synth and my plan is to implement some Eventide effects. For the moment I’d like to stay out of the box as much as possible, so my eyes (and ears) are on the H90 running in dual stereo mode, with one algorithm on the two front channels and another algorithm on the back speakers, but I guess if i should be running “true quad” i should be running a separate algorithm for each of the four channels….but that would require two H90s and i might quickly find myself in “overkill territory”…
        Does anyone here have experience using the H90 in a quad setting? How have you set it up?
        Anybody has experience with two H90 in a quad setup? And how have you set it up? Considering if theres a clever way of using the inserts that works better in immersive/quad…
        Are there any plans on implementing Blackhole immersive and micropitch immersive in the H90?
        Thanks! I know i should just experiment and find whatever setup works best for me, and thats most likely what i’ll end up doing….just asking for some advice before i throw myself in a “double H90 spending spree”…
