h90 – Routing Configuration – saved in Global or Program?
Home Forums Products Stompboxes h90 – Routing Configuration – saved in Global or Program?
    • #171168
      luedmo
      hello!
      I do not have an h90 (yet!) and cannot download the h90 control
      I have tried reading the manual and it is still not clear to me if the Routing Configuration for inserts is saved as part of a Program or as a Global setting.
      Ideally, it would be part of the Program, so we could have any combination of PreA, Parallel, Mid, or PostB in each Program.
      Also I wanted to confirm that it is possible to Bypass inserts via a MIDI #cc command issued from an external controller.
      Many thanks<
      luedmo
    • #171170
      Infection
      They’re  part of the Program and they can be individually bypassed with MIDI #cc.
      So basically yes.
      • #171172
        luedmo
        thanks for your help!
        That is what I hoped it would be
