I currently have my H90 running in dual mode as I wish to run each preset separately as each each effect is fed from a different mono source. I’d ideally like the H90 to just use 1 stereo output but it seems this routing is unavailable.
eg. I have from my Analog Rytm Clap into effect A using mono input 1. I have AR Hats going into effect B using mono input 3. Analog Rytm on has one stereo effect return so it would be really nice if I could route both effects to stereo output 1/2.
Is there a way to route them this way using insert mode?
I currently have 2x H90s set up as effect sends from the Rytm routed back into it using a Behringer rack line mixer but it would be great if I could get rid of two of those sets of stereo cables.
