H90 Scroll Through Algorithms While Locking Parameters?
Home Forums Products Stompboxes H90 Scroll Through Algorithms While Locking Parameters?
    • #172461
      owenc
      Hi, I wanted to test out the sounds of each Delay or Reverb algorithm while keeping my delay times and Mix knob settings etc the same. I know that each algorithm can have different parameters and I know I can roll through “presets” but every time I do that the time/delay settings etc change I have to re-dial them in when I switch form a Digital Delay to a Bouquet Delay for example.
      Is there a way around this?
      Thanks
    • #172462
      Sorry, there is no way around this. The presets have different mix settings and delay times, there is no way to lock these parameters.
      Your best option would be to create a few presets with the same mix and delay time using various delay algorithms if you’d like to compare the sound of the algorithms.
