H90 – Semi parallel insert loop?
Home Forums Products Stompboxes H90 – Semi parallel insert loop?
    • #185518
      tomasgunn
      I’m trying to set up a patch for a guitar lead tone that mixes the distorted lead tone (amp pedal) with a synth sound.
      I’d like to run the synth in slot A and then use slot B for delay.
      The trick is how to do the routing. I want to run the synth and amp in parallel. But the delay should come in series after that (i.e. delay affects both the synth and amp sounds).
      Is this possible somehow? From what I can tell, I can only run the insert in parallel to both A and B, but not in parallel to only A.
    • #185545
      Sorry, it’s not possible to have an insert in parallel with just Preset A.
    • #185547
      tomasgunn
      Thanks for the quick reply – I’ll survive in that case 🙂
      Could be a cool future addition in case this is something that could be useful to more players.
