Hi all, new H90 user here.
I have been using a H9 for 10 years to split my signal between two different amps as it has a output 1 dry/ output 2 wet -type of routing possibility.
Now, I´d like to use H90 in dual mode (pre/post) similarily. Let´s say to go guitar -> input 1 –> for example octaver in pre-effects with dry signal to output 1 and wet signal to output 2.
AND
Use the post section B in one amps effects loop.
Is this possible? If so, where do I set the signal routing split in outputs 1&2 ?
Thanks already!
