Home › Forums › Products › Stompboxes › H90 Software Latest
- This topic has 6 replies, 1 voice, and was last updated 10 months, 1 week ago by
Eventide Staff.
June 15, 2023 at 3:12 pm #171970
H90 Software Releases
June 15, 2023 at 3:12 pm #171971
H90 Release 1.5.6
This release contains minor bug fixes and improvements.TriceraChorus Preset Fixes
• For users of TriceraChorus prior to 1.5, this release fixes the behavior of the Env controls which are now separated out as Env Mix and Env Rate
• To maintain the sound of presets from prior versions (where the Env knob was non-functional), both these knobs will default to OFF when presets are upgraded from the previous 1.3 software
• If you had TriceraChorus presets imported from H9, they can be re-imported using H90 Control 1.4+ and the single Env control will map correctly onto the new Env controlsOther Bug Fixes
• fix Insert Polarity switch on the right channel of a stereo insert -
September 21, 2023 at 11:55 am #174262
H90 Release 1.5.7
- Fix an issue that could occur if you use certain Global Mappings immediately after the pedal boots in Perform Mode
- Fix tempo sync behavior during spillover – the spilling over program now maintains its old tempo when loading a new program
- Fix insert latency not instantiating correctly
- Fix HarModulator LFO shape Ramp Down
- Fix Even-Vibe envelope detect with stereo input
November 22, 2023 at 9:09 am #176030
H90 Release 1.6.11
Upgrading H90 Control to version 1.7.1 is recommended before installing this update
This release contains a brand new algorithm called PolySynth along with miscellaneous bug fixes and improvements.
New Algorithm – PolySynth
A fully polyphonic Guitar to Synth transformer, based on the same new SIFT technology found in the Polyphony, Prism Shift, and PolyFlex algorithms, and building on the earlier, monophonic HotSawz algorithm
- Up to 3 voices of synth tone, multiple modulation options, and envelope control of the filter cutoff
- Spread and Detune to create massively wide and thick sounds
- Adjustable attack time for ultimate playability or extra large swells
- ‘Freeze’ performance parameters to create infinitely sustaining synth sounds
Notes
- This release contains multiple internal firmware updates – the first reboot after installation will take a while as the firmware is updating
January 25, 2024 at 12:06 pm #177674
H90 Release 1.7.5
Requires H90 Control version 1.7.6+, please update H90 Control before installing the pedal software.
This release officially enables Bluetooth functionality for the H90! In addition, this release contains a few minor features and bug fixes:
- Implement a new Bypass mode in System Settings – “AB Only” allows you to bypass just the onboard effects, leaving insert routings active
- Add support for full user content backup/restore in H90 Control
- Add support for log retrieval from H90 Control
- Fix DIN MIDI stepping issue
April 9, 2024 at 12:07 pm #180776
H90 Release 1.8.5
Introducing 2 new algorithms — Aggravate & Sticky Tape
Aggravate is an octave fuzz inspired by famous classic analog octave fuzzes from the 70’s. This algorithm will satisfy all your fuzz needs with its versatile controls, rich feature set and most importantly, its chewy tone that makes playing through it addicting!
Sticky Tape is a new tape algorithm based on the same emulation technology as Head Space. It opens up a world of tape tone possibilities – all the character, grit, and modulation, without the complexity of a real tape machine.
Aggravate Features
- Screaming fuzz tone with 3 voices – Thick: off, Thick: On and Thick: MoreOn which adds a rich low end to your signal
- Octave is based on an ‘absolute value’ style octave meaning that it sounds much more organic than a pitch shifted octave up
- Envelope follower to achieve some dirty Queens-like tone. The filter can go from positive to negative envelopes and has 2 shapes, linear and exponential
- Pump controls allow you to duck your signal on rhythm via a rate or tempo knob OR you can manually pump your signal by assigning Pump to a performance switch or an external controller
- Tone and mid controls for the fuzz
- Bias control to make the fuzz more ‘spitty’, reminiscent of a dying battery on a classic fuzz pedal
Sticky Tape Features
- One-knob compressor based on the compression section of DBX companders found in many tape machines
- Two tape machines with an adjustable offset to get a wide range of doubling or slap back echo effects
- 4 different tape speeds for a variety of tone and character
- Wow and Flutter controls which can be used to create lo-fi detuning, subtle flanging, gooey chorus, or the extreme sounds of a machine that’s in desperate need of a tune-up
- Flange performance parameters to get that classic, dramatic, studio style tape flange
- Separate tunings of the algorithm for Bass and Guitar depending on the Instrument Type for best possible tone no matter the instrument
In addition, this release contains new software features and improvements:
Force Mono
- Override jack-detection and output mono even when wired for stereo
- Useful for patchbay setups or switching between mono & stereo rigs
- Preserves stereo information as long as possible through H90 effects and inserts for all routing configurations
- Found under System > I/O > Output Mode
Search by Favorites
- ‘Favorites’ is now available as a filtering option in Programs and Presets modes
- Use H90 Control to mark your Favorites, and then search by Favorites on the pedal
Other Improvements
- Fixed an issue where meter LEDs had inconsistent brightness
- Improve timing of internal MIDI bpm clock (for Looper in tempo sync)
- Fixed a benign warning in H90 Control about missing Programs
- Head Space tape noise reduced at lower settings
- Allow Vintage Delay & Tape Echo algorithms to load without warping effect
- Fixes issue with preset B when restoring from a backup
April 19, 2024 at 12:13 pm #181135
H90 Release 1.8.6
- Fixes no output on Ch 1 issue
- The topic ‘H90 Software Latest’ is closed to new replies.
