H90 Software Latest – H90 Release 1.9.7
Home Forums Products Stompboxes H90 Software Latest – H90 Release 1.9.7
Viewing 0 reply threads
    • #186423
      H90 Release 1.9.7 (Requires H90 Control 1.8.16)
      This release contains a number of enhancements for the Looper algorithm, as well as new UI features for live performance.
      In addition, this fixes a few issues that were found during the 1.9 Public Beta period, which is now concluded.
      New to 1.9.7
      • Fix issue where Looper beat counter could get out of step when synced to MIDI clock
      • Fix issue where recalled Hotswitch values can be slightly off
      • Fix an issue with relay bypass state not restoring from a backup
      • Fix text entry issues with some tempo-based knobs
      Previous 1.9.4 Release Notes
      Looper PERFORM Pages
      When the Looper algorithm is loaded into A or B, an extra page of parameters will appear in the PERFORM mode.
      These are transport controls for the Looper, now accessible from the H90’s built-in footswitches:
      • RECORD – Record, or toggle Dub.
      • PLAY – Play loop from the beginning, finish Recording or Dubbing.
      • STOP – Press once to stop the loop. Press-and-hold while the loop is playing to Undo/Redo. Press-and-hold while the loop is stopped to Erase.
      In addition to the footswitch controls, a large heads-up display provides feedback into the current state and position of the loop.
      The footswitch LED colors also denote the current state of the loop, for easy viewing on stage.
      Looper Algorithm Upgrades
      The Looper algorithm itself has also received numerous upgrades and improvements:
      • Separate Play & Record Speed knobs. You can now set the Play speed to an arbitrary value (at any resolution) and it will take effect upon playback of a recorded loop.
      • Add normal/reverse direction and full/half speed performance parameters
      • Fixed Punch dubbing mode. Allows you to use the independent Record footswitch as a momentary trigger (note: the One-Button Looper only works with latching mode)
      • Fixed an issue where Undo/Redo could bring back an erased loop
      • Fixed audio artifacts that could appear sometimes when playing back a loop
      Perform Overlay
      This feature expands on the functionality of the Perform footswitch parameters.
      Previously only visible in PERFORM mode, the Perform Overlay offers a heads-up display on these parameters from the other Play modes (SELECT List/Bank).
      In addition, changes to Perform parameters caused by remote aux switches or MIDI can be seen in the overlay across all Play modes.
      This opens up new possibilities for controlling the pedal in a live environment, allowing a wider range of use cases and configurations of onboard and remote controls. Together with Quick Knobs, the Perform Overlay offers valuable in-the-moment feedback for the H90’s playable parameters.
      Other Changes
      • Allow PERFORM page selection to be saved with Programs
      • Allow PERFORM global control to toggle between pages
      • Fix a lockup that could sometimes occur while using expression pedals
  • The topic ‘H90 Software Latest – H90 Release 1.9.7’ is closed to new replies.
