In the meantime, I am rebuilding my pedalboard with the H90. I have a Looperwerk connection panel on my pedalboard that allows me to sum a dual TS jack output to mono when connecting only one external plug:
“…If a certain external socket is not used, the mono signals present at both internal sockets are summed to the other external socket via a passive resistor network…”
Is this analog method the same as if I only use one output on the H90 or are there sound differences, possibly due to dedicated monophonic algorithms?
By the way, for those of us who use the H90 in the first of two rows on the pedalboard, it can be challenging to find the USB-C port after connecting all the cables 😉 This was easier on the H9.
I have now permanently connected a USB-C cable, which remains rolled up on site when not in use. I hope this doesn’t create any additional interference when it stays plugged in…
