Home › Forums › Products › Stompboxes › H90 swap feature and perform knob as master volume
- This topic has 3 replies, 3 voices, and was last updated 11 months, 2 weeks ago by
joecozzi
Eventide Staff.
February 8, 2023 at 9:10 pm #168986
chriscarrington.com
ParticipantIs there an option for swapping patches in the list view of the H90 software?
And, is there a way to assign the performance (hot) knob to master output volume?
thank you
February 8, 2023 at 10:37 pm #168987
Are you referring to the H90 Control software? If so, in the Edit window, on the top right, there are two arrows pointing in opposite directions. When you click on them you’re able to swap the order of the Presets within a Program.
Yes.
1.Press the Parameters LED button.
2.Continuously pressing Parameters will allow you to change whether you’re looking at the Program parameters (P), preset A parameters (A), or preset B parameters (B). The letter on the top left of the display indicates which set of parameters you’re working with. A short cut is pressing the P LED button above the first footswitch.
3.On the first page of Program parameters you’ll see “Out Gain” above the third Quick Knob.
4.Press and hold the third quick knob until you enter the Parameter Mapping menu.
5.Turn the second Quick Knob until Hotknob P is displayed under “Ctl Source.” You’ve just mapped the P Hotknob to the Program Out Level or Master Level.Tip: If you want to use an expression pedal to control the Output level, you can go into the System Settings, under Global – Pedal Ctl and assign any expression pedal to Hotknob P. Another option: map an expression pedal on a Program basis by entering Parameters mode and pressing and holding the Perform knob, where you can assign the hotknob to an expression pedal.
March 18, 2024 at 5:30 am #179737
matcaster
ParticipantBy swapping patches i guess he meant swapping 2 programs in a user list.
It would useful when you have one program/song and your band’s setlist is changing.
March 18, 2024 at 10:07 am #179741
Thank for the clarification. Rearranging programs on a user list with a simple swamp function is not possible on the pedal, but we can move things around easily using the H90 Control app.
